Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: A6, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay P2, Beoplay Earset
Lars Ladingkaer:This is selectable. This speaker has an option to lie down or to be wall mounted. When its lying down, then the left and right channel are opposite, of when the speaker is wall mounted. So when placing 'The Stage' like this, upside down, you would "cheat" and tell the app thats the soundbar is lying down, causing the channels to be at the right position. Regards, LarsAhh I set it as laying down now and the sound get improved Editor in Chief, recordere.dk Danish online magazine for consumer electronics
BeoVision Eclipse 55"...BeoLab 5 FRONT....BeoLab 4000 as REAR....BV5 HD....Beoplay V1-40....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
Noticed a strange thing when I played around with the borrowed Stage.
It had left / right channels on wrong sides.... I noticed that in a movie clip with clear left to right movement.
I double checked with a test track from Youtube and yes, it was mixed up.
I checked that the position was set right in the app, and it was correctly set as "wall" . I tried to change that to a table placement and that did no change to the sound at all....
After doing a factory reset, it was back to a correct setting of the left / right channels and also the toggling of "wall" to "table" made a differens (swapping left to right).
I did the initial setup from a factory reset, so it could maybe be worth for you Stage owners out there to double check that you have your channels "in the right place".
If you can't think of a track to test the left/right audio, I use "Girl you know its true" by Milli Vanilli (yes, I know it is not a great song!)
In the full version (with the conversation at the start), the girl's voice should begin in the left speaker, with the man replying in the right speaker.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Thanks for the tip! It’s weird. I checked it on my Stage, and it was the wrong way (moved it from Table to Wall).
Changing it in the app didn’t work. But changing it through the web panel did!
1990: Thanks for the tip! It’s weird. I checked it on my Stage, and it was the wrong way (moved it from Table to Wall). Changing it in the app didn’t work. But changing it through the web panel did!
I used this Youtube clip to test:
https://youtu.be/6TWJaFD6R2s
Steve at Sounds Heavenly:Hi, If you can't think of a track to test the left/right audio, I use "Girl you know its true" by Milli Vanilli (yes, I know it is not a great song!) In the full version (with the conversation at the start), the girl's voice should begin in the left speaker, with the man replying in the right speaker. Kind regards, Steve. Steve. www.soundsheavenly.com Sounds Heavenly are proud to sponsor BeoWorld!
Steve at Sounds Heavenly: "Girl you know its true" by Milli Vanilli (yes, I know it is not a great song!)
STEVE!... Shame on you! Plenty of Beatles songs with strong stereo separation!
Hi @all,
today i got a BeoSound Stage in Oak to test from my dealer.
I also have a BS Essence with two BL5 connected to it.
My dealer couldn't tell me if the following scenario is possible:
BS Stage via HDMI ARC on Samsung TV and the Essence playing the TV Sound via Networklink from the Stage
I tested now and couldn't get it working.
Maybe i miss something, or is this not possible ?
The Stage is great, but it would be nice if i could activate the BL5 for even more power / fun :)
johannes2912:Hi @all, today i got a BeoSound Stage in Oak to test from my dealer. I also have a BS Essence with two BL5 connected to it. My dealer couldn't tell me if the following scenario is possible: BS Stage via HDMI ARC on Samsung TV and the Essence playing the TV Sound via Networklink from the Stage I tested now and couldn't get it working. Maybe i miss something, or is this not possible ? The Stage is great, but it would be nice if i could activate the BL5 for even more power / fun :)
thanks Hiort,
i cannot link the two products together in the App, so i think its not posslible.
Is the Essence like the Core? I have the Stage, Core and Apple TV connected to a Sony TV, in my experience I can output to both Core connected speakers and Stage at the same time with no delay using AirPlay 2. In my set up the Apple TV is connected to the Sony TV via HDMI and the above works even when my Stage is connected to the TV via HDMI ARC. However, I have my Stage in my dining room, not connected to any display because of how good it sounds in that room 🤷♂️ However, I have tried it with my Sony TV as well to test the Dolby Atmos Audio (From Apple TV 4K to Stage (HDMI) and then from Stage to TV (HDMI Arc). So if Essence is like Core and the new Samsung TV has AirPlay 2 support (since I know they have Apple TV built in now) you might be able to get all the system to sync up using Apple AirPlay 2. You can probably do it via Chromecast as well but I haven’t tried it.
B&O in my life 😊:
Did you experience any sound sync problems?i also have C9 65” and Stage. ATV4K everything is out of sync :-(
the Stage directly on HDMI ARC is perfectly in sync as far as i see (hear).
The builtin AppleTV app cant play the sound via Airplay to any speakers.If it can, i dont see it, there is no menu point in the settings, etc.
johannes2912:the Stage directly on HDMI ARC is perfectly in sync as far as i see (hear). The builtin AppleTV app cant play the sound via Airplay to any speakers. If it can, i dont see it, there is no menu point in the settings, etc.
Software update tonight. I’m at 1.8.37133 now. Anyone knows what’s updated? (Btw: the M3’s are at 1.7.36614 since today)...
Bumping it up as I do have the same question about the sw update... if someone have figured it out what's new in this release?
steve1977:Can you confirm whether deezer/dlna/tunein still work since the update?
Yup. Still works.
1990:Btw: the M3’s are at 1.7.36614 since today)...
Hello,
i would like to realize the following set up:
The computer monitor ... LG 32UL750-W ... that has no HDMI ARC, but 2xHDMI inputs and a 3.5mm audio jack output + 2x USB 3.0 outputs ... shall be used with a Apple-TV 4k (HDMI output) and the Beosound Stage, that has HDMI, HDMI ARC and 3.5mm analog inputs.
I would like to be able to use the set up to watch live tv via the waipu.tv app over the Apple-TV ... and watch netflix, youtube and others. The sound should be delivered from the Beosound Stage.
Has anybody an idea, how this could be achieved, since the monitor has no HDMI ARC but simple HDMI only? How should the system be connected?
Best regards
Tom
Use a HDMI splitter from the ATV to 1: the monitor and 2: to the Stage....that should do the job.
Something like this sounds promising:
https://www.amazon.de/FeinTech-VSP01222-Splitter-Eingänge-AV-Receiver/dp/B08KFD4XGK/ref=mp_s_a_1_1?currency=EUR&dchild=1&keywords=feintech%20vsp01222&language=en_GB&qid=1607034721&sr=8-1
What do you think, Millemissen?
https://feintech.eu/hdmi-splitter-mit-arc-pass-fuer-av-receiver-soundbar
Sorry ... wrong product ... it should be this one:
https://feintech.eu/hdmi-switch-mit-arc-und-earc-pass
