beogram 8002 sticking tracking arm
Not Answered This post has 0 verified answers | 2 Replies | 1 Follower
terry
vancouver island bc canada
terry posted on Thu, Aug 15 2019 6:22 PM
My 8002 starts fine but stops part way through the record (about 1/3) the tonearm then appears to continue and then push up against the tracking arm, the record continues to play but not move forward. What might be causing this. This is a new to me unit and this is the first time that i have tested it.
Dillen
Copenhagen / Denmark
Dillen replied on Thu, Aug 15 2019 6:57 PM
In order of likelyness:
- Teflon sheet from lid damper has come lose and moved down, blocking the carriage.
- Dirt and/or dried lubricants on the threaded shaft.
- Bad or wrong carriage motor belt
- Electronic problem
terry
terry replied on Fri, Aug 16 2019 7:36 PM
Thankks Martin for the info, I have a couple of questions tho, where and what is the teflon sheet located and how do I access it? How to remove the plastic deck, is it the big round screw under the aluminum lid?
Page 1 of 1 (3 items) | RSS
