Is there a way to connect a BeoGram 6500 directly to a B&O multiroom wireless network and without the BeoMaster 6500?
Not Answered This post has 0 verified answers | 6 Replies | 3 Followers
bonbazar
bonbazar posted on Wed, Jul 31 2019 5:54 AM
Hello!
I am trying to do something that seems impossible... I would like to connect a BeoGram 6500 & a BeoGram CD 6500 to my multiroom wireless network (+/- 6 pair of speakers). I bought a second-hand NL/ML converter and do not want to use the BeoMaster 6500, but connect straight away the Beogram's on the network. Is there a way to do it? Which type of cables and extra converters are necessary to do so? I am a bit loss...
The reason I want to by-pass the BeoMaster unit is that it is particularly heavy and I can not transport it easily (need to tak e a flight, etc.). Also, it is useless as all speakers are active and I don't listen to radios.
I would like to control the BeoGram's with the B&O mobile app.
Thanks,
Emmanuel
Tito2019
Bonbazar
这是一个电缆,电线产品链接http://www.endezohk.com/list/cables-wires.html
转换器产品列表页面http://www.endezohk.com/list/integrated-circuits-ics_data-acquisition-analog-to-digital-converters-adc.html
我希望能帮助你。
铁托
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Hello Emmanuel,
Thanks for your enquiry (please ignore the reply above, this appears to be a spam posting?)
Please can you let me know which other wireless B&O products you have in the house, especially noting which ones will be in the same room as the Beogram 6500?  I can then help you to get these working together.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
bonbazar
bonbazar replied on Wed, Jul 31 2019 12:09 PM
Thanks Steve for your quick reply. In the same room as the Beogram CD/Phono, I will have a have Beolab 3 connected to a B&O Essence. In other rooms I have Multiroom Speakers (e.g. Beoplay M5, Beoplay A6 & Beolab 2 mainly). Hope it helps. Emmanuel
Hi Emmanuel,
Thanks for your reply.  playing the Beogram to any room wirelessly can be as simple as plugging it into the Line In sockets of the Essence via this cable:-
https://soundsheavenly.com/beogram-record-players/14-2244-beogram-to-non-bo-device-phono-pre-amp-receiver-amplifier-etc.html#/2-length-1m/60-grounding-internal_ground_link
Steve.
bonbazar
I want to be able to control the Beogram CD with the app...
Hi Emmanuel,
That is possible, but more complex.  You will need the Beomaster 6500, an ML/MCL converter and an ML/NL converter.
The other option is to use a Beosound Ouverture to connect the Beogram to, then you just need the ML/NL converter.
Please let me know if you need any help with cables for either of these options.
Steve.
Page 1 of 1 (7 items) | RSS
