Introduction BeoVision Harmony
Not Answered This post has 0 verified answers | 78 Replies | 1 Follower
kuyttendaele
kuyttendaele posted on Sun, Jun 23 2019 11:35 AM
Soooo... last Friday there was an introduction event of the Harmony at my dealer's place.
Some pictures here: https://www.flickr.com/photos/kuyttendaele/albums/72157709213805051
My remarks:
The set is BIIIIG... but at the same time it's a piece of art when in the OFF/sound modus. What I didn't know was that there's a small led light between the speakers that turned on when the speakers fold open or close :-)
Soundwise no complaints at all... Picture quality to notch on 4K HDR and the set does a pretty good job on turning standard 1024p stuff onto the big screen.
Pricewise... This set is more or less the same price as the BeoVision 5 (or 9) if I recall. So there is definitly a market for the set!
I was hesitant when I first saw the pictures online. But you have to see the set in real life to appreciate it. B&O have done a very good job in turning a standard LG screen into something special!
Afterwards received a nice bottle of B&O rum... Haven't tasted it though.. But it'll probably have some software faults *joke*
Karel.
Sandyb
Sandyb replied on Tue, Jun 25 2019 12:20 PM
Good stuff, although many of the Ces announced flahsgips haven't been reviewed yet.
The Panasonic flagship OLED goes to 1000 nits they say, but reviewers won't have it for a few months yet.
I'm expecting it to easily top the other OLED flagships in terms of picture quality.
Mikipidia
I somehow doubt that panasonic gets more brightness out of the exact same panel, maybe on a 1% box but certainly not on a 10% box. The review I saw said the lg basically followed the sdr and hdr brightness curve perfectly up to 800 nits and then sloped a bit. apparently what ever ''short comings'' the c8 panel had are totally gone. It'll be an even closer margins game this time around I suspect, as in the tv's will be with in 2% of each other and that probably is close enough that cherry picking the actual oled panel starts to matter.
New: Beovision Harmony, Beolab 50's, Beolab 18's, Beolab 17's, Beosound 9000 mk3, Beosound 1 Bronze edition, Beoplay M3, Beoplay A1.
Mikipedia on YouTube (finally Stick out tongue )
https://www.youtube.com/c/Mikipedia
Old: Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Sandyb
Sandyb replied on Tue, Jun 25 2019 1:08 PM
Subject to the caveat that reviewers haven't got their hands on the Panasonic GZ2000 flagship....
The deal they have with LG is to take some panels early off the production line, just before LG finish off the process.
As such Panasonic have changed / improved the heat management, and has allowed them to run the panel at 1000 nits.
Thats what they have told AV Forums, with whom they seem to have a good open dialogue.
As for whether Thera re other benefits from their early selection of panels (uniformity etc?) I can't remember. But the above is the relevant point with regards to brightness. This applies only to the flagship GZ2000 Pro Panel, not the rest of their 2019 range.
Michael
Sweden
Regarding OLED and brightness compared to LED backlit screens. The OLED pixels themselves produce light and can usually flow extra bright for a shorter time whereas LED backlit screens can shine at the maximum level steady usually.
The OLED panels suffers from getting dimmer due to the organic design and also heat and power issues over the panel area. So even if an OLED can shine bright, it can only do so for a shorter period of time before it has to dim down to not wear out to quickly in spots, or to heat up to much to cause lower life and also because the panel can’t output enough power to shine the entire screen at full brightness - neither for longer periods. Meaning that OLED screens can shine bright in smaller areas or dispersed over the screen in smaller segments and just for limited time.
A LED monitor with a good backlight system is usually better brightness wise. Just look at Apples new Pro XDR screen for example.
Even on an iPhone you’ll see that they throttle down the max light if there’s a lot of bright areas on screen or high brightness level - if you have one with OLED. The LED counterparts shine brighter and stays bright.
OLEDs main selling point is that they can turn off and therefor show complete blackness. And also be thin. But the negative side is simply that it struggles to shine.
Sandyb
Sandyb replied on Tue, Jun 25 2019 4:24 PM
https://www.flatpanelshd.com/focus.php?subaction=showfull&id=1551171164
sort of explains what Panasonic are doing with the LG panel.
But as they say, we'll have to see in real life.
BEOVOX141
Denmark, West
Silver Member
@ Michael
Add to that,- on smaller panel sizes the problems you list will increase due to the smaller active area. There was properly some cleaver reasoning behind choosing the 55 inch as the starting size.
Emil Jensen
Denmark
Beovision Eclipse, Beolab 5, Beolab 17, Beosound 1 Google assist, Beoplay M3, Beoplay H6, Beoplay Earset
Emil Jensen
Denmark
Emil Jensen:
<a href="https://beta.photobucket.com/u/emilos88/p/616a9fa3-5cca-471b-b7c2-6c29342a0169" target="_blank"> <img src="https://hosting.photobucket.com/images/ab181/emilos88/0/616a9fa3-5cca-471b-b7c2-6c29342a0169-original.png?width=1920&height=1080&fit=bounds" border="0" alt="Skærmbillede 2019-06-25 kl. 19.47.51"/> </a>
BEOVOX141
Denmark, West
Silver Member
Interesting the price point is 10% below one big store. So the question is: Where would you want the warranty for the OLED to be issued?
Michael
Sweden
Michael replied on Wed, Jun 26 2019 11:43 AM
BEOVOX141:
It’s also without stand, remote and speakers. The warranty should come from B&O if you buy the TV from them. I remember B&O saying that a screen could also be bought separately but that’s another story.
Simonbeo
My wife and I went to see the Harmony launch last night and were reminded what makes B&O special. Having the demonstration and background story about Valeur harking back to the original “wheelbarrow” tv made it all make sense. All except the sheer scale of the Harmony!
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
Millemissen
Flensborg, Denmark
ONLINE
BEOVOX141:
The BV Harmony isn’t released yet.
How will the price of a stock C9 be in October (when the Harmony will be in the shops) - probably not like in your screenshot.
Apart from that - it is weird that a specified pricelist is already released by now - why?
Emil Jensen
Denmark
Michael:
BEOVOX141:
Hallo Michael,
The TV is with Stand, remote and speakers, it is the same C9 as you can buy in other shops.
So yes the price is cheaper than there common stores, but as Millemissen points out, lets see in October.
Aussie Michael
Melbourne, AU
Regarding the sound Karel,
I was looking up the specs of Harmony and saw that they are 450W and the eclipse is also 450W
The speakers on the harmony look very tiny and not near as big as the ones on the eclipse.
Would you say, if you have heard an eclipse,is a harmony better or?
To me it seems all of the space of the butterfly effect of the harmony speakers is taken up by plastic rather than actual speakers.
Happy to hear your thoughts as you have heard it.
M
Mikipidia
the harmony isn't tuned yet. the speakers are mostly the same. tweeter and full ranges are the same. the mid range is the one from the bl50 and the two underneath are the same a s in the eclipse.
So it should sound better probably, but nobody has heard the final tuning yet.
Page 2 of 6 (79 items) < Previous 1 2 3 4 5 Next > ... Last » | RSS
