BV 6-26 int. Sat Module
Answered (Verified) This post has 1 verified answer | 2 Replies | 1 Follower
mafanni
mafanni posted on Thu, Apr 18 2019 3:07 PM
I am having trouble to add a new satellite. Hotbird and Astra 19. Astra 1 and Hotbird are working fine. I can receive this satellite with my other TV's I also know the diseq switch setting.
Can anyone help with that or can anyone send me a link to the sat. module manual please.
This is the satellite-transponder I would like to add:
Digital Satellite 1
Astra 2E (28.2° East) Transponder 45 Frequency: 10.77325 GHz Horizontal polarisation Modulation: DVB-S, QPSK Symbol rate: 22.0 Mbaud FEC 5/6
Transport Stream ID: 2045
Thanks for your help.
Keith Saunders
Little Ann, Hampshire, United Kingdom
Verified by mafanni
I am assuming from your first sentence that your BeoVision 6-26 and your other TV's are using the same dish. Please confirm.
How are you trying to add the new satellite?
The best way to add a satellite is to use the "SEARCH" function by going into SETUP then CHANNEL/STATIONS then SEARCH
In the SEARCH menu, you set your preferences for a channel or station search:
POSITIONS … Select which position you wish to search from, hide* or show positions in the list or edit position information – Use the “edit” function to change the settings for a chosen position.
SEARCH FILTER … Select whether to search for all channels or free-to-air channels only.
SEARCH MODE … Select either automatic or manual search.
FREQUENCY … If you have chosen manual search, you can enter a search frequency.
SYMBOL RATE … If you have chosen manual search, you can set a symbol rate value.
NETWORK SEARCH … If you have chosen manual search, you can search for all channels and stations found in a specific network by choosing "YES"
Regards Keith....
Keith Saunders
Verified by mafanni
Regards Keith....
mafanni
mafanni replied on Sun, Apr 21 2019 12:30 PM
Dear Keith,
thanks a lot for your reply, yes All TV use the same dish. I tried your way, and it worked perfectly fine. Thanks so much and have a happy Easter,
Erik
Page 1 of 1 (3 items) | RSS
