Beo6 battery and dock
Not Answered This post has 0 verified answers | 47 Replies | 0 Followers
matador43
matador43 posted on Tue, Apr 16 2019 10:51 PM
Hi Guys,
I was given a BEO6 in gold finish and in aesthetically perfect condition.
BUT,
The battery is dead and there is no docking station.
I did find some spare battery modules not that expensive, to replace the original ones who add a leak (which fortunately doesn't seem to have corrode the main PCB).
Lets say I can replace the battery and the remote start up, do someone know how the charge the battery without the dock, like connecting any power supply to pin X and pin XX in the base and… It will work! (beo6 base are very expensive on eBay).
Finally, as I dont have a base, I suppose I won't be able to customize the control it can handle? Is it true or is it any "learning" mode who dont need software and connection?
Thank you all for your help. I jut hate to have perfectly looking object, not working internally. It's beyond my understanding that when the container is fine the content is faulty. I know, I live in the wrong time Big Smile
matador43
Weebyx:
Yes, the red arrows indicate no connection to a remote.
Does windows find the remote under device manager when you dock it ? The first thing is to just leave config tool closed, and get windows to display the Beo under Device Manager. Sometimes it cannot find the driver automatically, so you just select the remote under devices and manually point driver to the BeoDriver folder under the installation path.
/Weebyx
Hi Weebyx,
I'll try this later today. As you know, i'm on Mac, so I have to first install a virtual machine on an old Laptop to avoid the USB 3.0 issue I read about.
So far I've tried on a virtual Windows 8.1, with the Keith Saunders workaround about "Driver Signature Enforcement" but on a USB 3.0 laptop and without any success.
Of course all tips and tricks about Windows Use are more than welcome.
M.
stampfki
Which devices you want to control with the Beo6?
matador43
Weebyx:
/Weebyx
Ok, I've installed a fresh new Win XP on an USB 2.0 (Mac) Laptop. I've tried to explore de Device Manager without any luck (please see screenshot below). Tried to Install CT 5.12 to see what happen but nothing happened.
One question thought, because I have not replaced the battery yet: Does the battery be healthy when the remote is docked and the USB power supply will power the electronics or do I need to replace the battery first thing first? The battery is 1.2 V over the 2.4 by design.
Thanks.
matador43
Something happened !!! Lets have a Party !!!
I teared appart the Beo6 in four part: screen, PCB, dock connector and battery and i fueled the PCB with 2AA batteries (again!), connected all things and docked the connector to the base. As soon as I connected it to the Mac it showed up in the Mac Device Manager equivalent.
Then I tried on my virtuel win XP where it show up too, was able to install driver with the Weebyx method above…
And, Voilà ! the arrows in the CT windows loose their red cross!
Registered the remote, created a new zone and added a new device. Uploaded to the remote in CT 5.12.
Thats where I'm stuck now. It did send some data but stop on the "Writing Wifi Firmware" and get stuck there for more than 30 min (yet knowing old laptop and virtualization is slowing down everything).
Any advice? Thanks
Weebyx
Denmark
matador43:
Any advice? Thanks
The WiFi update is only 8KB or something if I remember, but it can take a very long time(I have seen more than 30 minutes on a "real" windows pc). If the battery for the remote is not fully charged, it might fail because of low battery, but it will say so in the config tool.
If the screen came to life when you did the update with tool 5.12, I would try with 6.00 and do the update again.
What I usually do with these remotes, is that I have a new batterypack(created by my self from a old not working), that I have in a working remote with loose keyboard so I can change the battery pack quick. This remote is used just for charging the battery pack used in the remotes I get to life :)
/Weebyx
matador43
I was going to write "unfortunately the screen didn't came to life"…
BUT
Here is what I noticed this morning!
The screen showed this message and even the remote keys illuminates.
But we're not done yet! The wifi update taking forever I stopped the process, installed CT 6.00 and tried to send an new config to the remote.
At the second step I get the "Low Battery" alert! After fully charging the batteries I get the message again. The black batteries are 2450 mAh versus the 1200 mAh from the original pack so I assume the batteries are not actually low.
matador43
Update!
Somebody lend me a Thinkpad with Windows XP on it. I was able to connect the remote and start CT 5.12.
But the upload to the remote get stuck at the same step "Wifi…". I let the computer for more than 60 min but nothing happened.
I swapped the PCBs and tried the process again and it get stuck again, same step.
Is there some electronic into the screen which can cause some communication troubles?
Or is it something special to do into CT? Is the serial number you enter to create a remote relevant (IE, need to match the PCB number or something).
Thank you.
marexy
marexy replied on Tue, May 7 2019 12:14 PM
hi
I can not help but it is nice and a big help to others who check your progress with that problem.
I wish you a successful repair and satisfying use for a long time :)
matador43
Thank you marexy!
What I've learned so far:
Part of the electronic including the main "brain" must be in the display part. As you know I have two remotes a Silver and a Gold. The silver one is known as Faulty Display. When I connect it, the display show two zones, USB in blue and the bottom buttons. But the screen is unresponsive.
When I connect the Gold one, it shows "No valid configuration". When I swap the displays, the messages follows the screen, no matter what main PCB (keyboard) I use.
So to me, solution is in setting up the gold one but I can't because of the above issue: CT 5.12 get stuck at wifi config step, CT 6.00 dont upload to the remote because of a Low Batt alert.
So I believe that the problem may come from the remote being powered not enough; But I can't understand it as i checked voltage and it was 2.5 volts and the cells are rated the double mAh than the original battery and f course fully charged.
Any hints?
matador43
I give up!
After more than an hour and a half on a true PC, CT 5.12 is still updating Wifi Firmware. I aborted the update.
Other CT stop at the BeoLO step claiming battery is too low.
I've ordered 2 4/5AA 1300mAh cells to build an internal battery, they should be there next week. We'll see then.
Thanks to anyone who helped so far.
marexy
Hey..
Do not give up...ok..after batery change go on with repiair  :)
I have some problem to with Beomaster 5 motherboard and for now i had enough ...Will try later.
And some time ago i did some repair on BS9000..maybe 20hours lost...but after 6 month did start to rapir it again and ...wolaa..after 2 hour work BS start to working like new :)
so ..it's never to late :)
good luck :)
Weebyx
Denmark
matador43:
I give up!
Try with the latest config tool (6.84) instead of 5.12. It seems that this WiFi update is troublesome, but it needs a good charged battery pack, that is my experience.
Give it a go with 6.84, it that fails, try 6.62 and then back to 6.0 :) You need patience and the different version of the config tool depending on which tool has done the last update in the Beo6. There are som weird differnces :)
/Weebyx
matador43
Hi Weebyx,
Tant you for your support. I have put the original battery pack which came with the silver remote to charge overnight. This morning it was checked at 2,5v.
I'll try a new update with CT 6.84 as suggested and let you know. If it dont work I'll wait until next week and try again with new fresh cells.
A couple of question if I may:
- Can the 'No valid configuration" message be a symptom of another problem. I mean, did you already see it when you knew the remote had no other problems?
- How difficult would it be to dismantle the display.: separate the screen from the main PCB. Because I was able to turn ON the silver remote, see 2 zones, navigate into the setup menu and even choose my local wifi network. Just the screen is unresponsive (as expected).
Anyway, I keep faith that problems will solve with new batteries. I'm just confused about how sensitive the system is to very light variations.
matador43
I tried again and had the same message "Battery too low". Battery is checked at 2.6 volts.
I'm not too much into volts and amperes but because the silver remote also turn of because of low battery I would assume than its the mA that are weak.
I had the same issue with a BS3 power supply which did have the required 15V but just a quarter of mA, so the unit turn on and off the second after.
Only thing that still bothers me is that I'm unable to even enter setting mode with that one. Only 'No valid configuration" message.
Now hope the new cells will solve the problem!
Enjoy your day.
Weebyx
Denmark
matador43:
Enjoy your day.
"No valid configuration" will do that the remote is totally unresponsive, that is normal.
Wait for the new battery pack, and do a complete 24hour charge of that battery. You cannot use "the battery is checked" for anything in these remotes. They are bad designed, and can think that the battery is bad even though it is fully charged.
I have had remotes that needed many times of a fully charged battery, and upload of FW/WiFi/configuration before it came back to life.
Off course, it is also possible that it is actually faulty, but I dont think so.
I bought 10 "faulty and dead" units at some point from my dealer. All of them came back to life with new batteries and the latest firmware.
/Weebyx
Page 2 of 4 (48 items) < Previous 1 2 3 4 Next > | RSS
