BeoLab 5 - High sound when switched on
Not Answered This post has 0 verified answers | 4 Replies | 1 Follower
aengdal
aengdal posted on Sun, Feb 17 2019 2:05 PM
Hi There,
My left speaker gives a high sound when it is switching on (activated). It sounds like a loose connection or overvoltage. All electronics (the chassis) was replaced 6 months ago, and I was wondering if it somehow was related to that.
Any ideas?
Cheers
Anders
Mr 10Percent
So West, Its Now East
Too vague a description but a quick guess of the lower end of serious is can you check if you’re upper tweets are preforming?
obtain some frequency test tracks (L&R) if you can find and see if all tones come through correctly.
I lost an upper tweeter once and  (don’t think I heard it pop but) but on replacement I quickly acsertained the second upper was not performing as well as or equally as the replacement. I would uly alwayes recommend replacing them as a pair
if the tones are correct, it’s internal electronics. If not, replace faulty drivers
aengdal
I have requested a service guy. The chassis was replaced one year ago, and it's most likely the issue.
aengdal
Once again..a new chassis (all electronic was replaced)
aengdal
Page 1 of 1 (5 items) | RSS
