BM2000 fuses blow on amplifier board
Not Answered This post has 0 verified answers | 15 Replies | 2 Followers
Aad Jansse
Rotterdam (Neth)
Silver Member
Aad Jansse posted on Sat, Feb 9 2019 3:17 PM
Playing some tapes on my newly "belted"  BC1200 hooked up with the BM2000 the latter fell silent all of a sudden; after getting access to his"belly" I found 2 blown fuses, F102 and also F201 which one is depicted here. The other two fuses could have stand the current for the short moment that I had the power on.
 The question is, no surprise, what is the cause of the blowing and where to begin checking; it seems not so easy since I can not test with power on.
As in all my previous threads on this forum: help is much appreciated.
Aad
W.Frankenberg / Gandalf
Heilbronn / Germany
can it be that the rectifier has a short circuit in the AC range? (~ ~), disconnect the orange wires and then measure the transformer output voltage.
the trafo gets hot ?
Is 220V on the primary side of the transformer?
If not try to set the input voltage to 240 volts and measure again.
Worst case: the transformer is gone
wilfried
Page 2 of 2 (16 items) < Previous 1 2 | RSS
