BS9000 MK2 vs MK3
gerard
Luxembourg
Posts 202
ONLINE
gerard Posted: Mon, Jan 21 2019 9:28 AM
could you tell me the differences between MK2 and MK3.
Is the MK2 obsolet, may it work with my BV10 ?
Thanks for your help.
Guy
Shropshire
Posts 1,443
Guy replied on Mon, Jan 21 2019 11:02 AM
The main differences are listed here: https://www.beoworld.org/prod_details.asp?pid=954
And you should be able to connect either BS9000 version to your BV10 with a masterlink cable in order for them to work together.
If you have a Mk2, then there is a chance that 'N.MUSIC' will not work, as explained at the link under TOP TIP 2.  This may not be a problem in your setup.
gerard
Luxembourg
Posts 202
ONLINE
gerard replied on Mon, Jan 21 2019 11:29 AM
TopTip 2 is great info, as I have a PClink2 and a Beosound5, both are not linked together
Page 1 of 1 (3 items) | RSS
