B&O 3D Prints
Not Answered This post has 0 verified answers | 42 Replies | 4 Followers
Christian Leicht
Aarhus, Denmark
Christian Leicht posted on Sun, Jan 13 2019 3:43 PM
If anyone's interested i just added a lot of my own custom B&O 3D prints to my website. They are free to use.
You can find and download them right here: https://leicht.io/projects/3d-models/
Kind Regards,
Christian Leicht
https://leicht.io - B&O Custom Parts & 3D Models
Jeff
USA
Silver Member
Jeff replied on Sun, Jan 13 2019 6:34 PM
Let me take this opportunity to express my appr citation and respect for what you’re doing. Helping people with parts tor classic B&O that have been unavailable for many years must truly be a labor of love for you, and a great benefit to B&O lovers. Thank you for your efforts!
Jeff
Evan
Germany
Evan replied on Sun, Jan 13 2019 6:45 PM
As I said on FB a little while ago - great work! It's amazing to see what you can cleverly reverse engineer with just a set of calipers and a few gauges.
I 3DP as much as I can for my hobbies (B&O included) but it is difficult when you don't own a printer yourself Stick out tongue Usually I go to Shapeways to get my parts made. Its the only way I can get a reasonable deal on sintered parts.
Beo4 'til I die!
Orava
Finland
Orava replied on Mon, Jan 14 2019 9:17 AM
Great. I did try BC9000 CD holder years ago, but then 3D printers (what I could reach) did could not do good enough. Maybe I should try again if there is improvement happend.
Evan
Germany
Evan replied on Tue, Jan 15 2019 2:36 PM
Orava:
I'm not sure exactly what part you are referring to, but if you need more detail (higher precision) and better durability, SLA might be a good option for this. Shapeways also has this service available. Or find someone with a Form1/Form2 from Formlabs.
Beo4 'til I die!
Orava
Finland
Orava replied on Wed, Jan 16 2019 9:00 AM
That in the middle
Orava
Finland
Orava replied on Wed, Jan 16 2019 9:02 AM
Original
Beobuddy
Utrecht, The Netherlands
I received an abused BG3300 for repair/overhaul.
Plastic part was broken where the tonearm is adjusted when it floats accros the record or rests when in standby.
Beobuddy
Solved by designing a small part and printed with a 0,25mm nozzle.
The journey between designing and finally usiing the printed part can be very satisfying.
Beobuddy
When the gearwheel from the BG4000 is broken, just print another one.
matador43
I've just get a Beolit 707 slider 3d printed by my nephew.
The model seems to be accurate and it works but we still need to wok on aesthetically aspects and print quality! Big Smile
I've attached the model to this post.
W.Frankenberg
Heilbronn / Germany
I habe exactly the same Problem with one oft my beograms (See my post Form last year beogram 3500)!
Is this 3D printed part available?
How can I get 1 vor 2 oft this part?
wilfried
W.Frankenberg
Heilbronn / Germany
I habe exactly the same Problem i need this part!
wilfried
Beobuddy
W.Frankenberg
Heilbronn / Germany
Big Smileyes the part is signed with a red arrow in position K
wilfried
Page 1 of 3 (43 items) 1 2 3 Next > | RSS
