Beoport n.radio web access no longer available
Answered (Verified) This post has 2 verified answers | 30 Replies | 6 Followers
alfio
alfio posted on Tue, Jan 8 2019 3:28 PM
Dear All
as  announced the N.Radio support ( used by beoport) via the http://nradio.beoplayer.com/nradiodata.asp is no longer  available the domain has been dropped.
I was wondering is it could be possible to emulate it  in order to connect to the many free radio available on the web.
I do not know the detail of the interface apart from the registry information that identify the web site and an id.
[HKEY_CURRENT_USER\Software\Bang & Olufsen\BeoPlayer\N.Radio]
"ViewSelection"=hex:00,01,02,03,04
"BufferTime"=dword:00000005
"ServerURL"="http://nradio.beoplayer.com/nradiodata.asp"
"UserId"="60B1D8994C224AC69B91931AE710521A"
"SoundIcons"=dword:00000001
"EnableDebug"=dword:00000000
Regards
gerard
Luxembourg
Answered (Verified) gerard replied on Mon, Jan 14 2019 12:33 AM
Verified by expoman
I have BeoPort running on a Vista-PC, it still plays N-Radio, my BS5 also plays Internet-Radio
Could I check something for you?
frog
Camberley UK
Answered (Verified) frog replied on Mon, Jan 14 2019 1:25 PM
Verified by alfio
I have 3 other Beosound 5s and the two others I've tested seem to work OK. now - must be something else with the one that couldn't connect. I'll have to have a closer look.....
kimhav
Sweden
Well, if one could get hold of what ever B&O had as script on this domain it could be cloned on a local resource at your local LAN. Would be easy to redirect the domain with a static dns pointer in a consumer router.
Has anyone reached out to B&O to request this or thought about salvaging the domain?
frog
Camberley UK
frog replied on Thu, Jan 10 2019 9:54 AM
I’ve submitted a request to https://bogo.custhelp.com/app/ask just below:
It seems that the http://nradio.beoplayer.com domain has expired, but this is the domain that provides internet radio to all my devices (beosystem 2, beosound 5, beoport etc.)
Would it be possible for you to renew the domain and resurrect the script. Failing that, could you provide the script so that users can re-direct the n.radio requests correctly?
they say they will get back to me in a couple of days.
i really hope they reset this domain. It’s not as if it is costing them a lot!
frog
Camberley UK
frog replied on Thu, Jan 10 2019 1:39 PM
Just got a reply - the question has been referred to their tech department in Denmark - so here’s hoping!
vikinger
Vestri Kirkjubyr, UK
 N Radio still seems to be working on the BV11. Different domain?
Graham
frog
Camberley UK
frog replied on Thu, Jan 10 2019 10:33 PM
Hope for you that is the case. On my beosound 5s, the domain is the same as the one above. Hopefully B&O will resurrect the domain and maybe link to whatever the BV11 is using if they have to.
alfio
alfio replied on Thu, Jan 10 2019 10:37 PM
Actually I can only confirm that it is working on my BV Avant 55.
alfio
Millemissen
Flensborg, Denmark
It sure is!
ebnrob
South East England
ebnrob replied on Fri, Jan 11 2019 10:15 AM
Hi Frog,
I've also contacted beocare about this N.Radio issue on the beoport. Fingers crossed they will fix this.
Rob.
frog
Camberley UK
frog replied on Fri, Jan 11 2019 6:19 PM
Thanks, the more that do, the likely it will be fixed.
frog
Camberley UK
frog replied on Fri, Jan 11 2019 6:22 PM
As an aside, what would be a simple addition (not replacement) if they don’t fix this? I was using it to listen to radio stations in a different country. I’d ideally like it to be activated on pressing the Radio button (like it does with the Beosound 5) and I have an all-ML setup.
alfio
alfio replied on Fri, Jan 11 2019 10:19 PM
Hi
 as Kimhav mentioned it woudl be enough to get the script used by B&O to simply emulate an interface over a small pc / a raspberry Pi  to interface the existing web radio.
Regards
frog
Camberley UK
frog replied on Sat, Jan 12 2019 6:22 PM
Yes, I know that as it was mentioned. I was asking about what other device would do the job.
gerard
Luxembourg
Verified by expoman
Page 1 of 3 (31 items) 1 2 3 Next > | RSS
