Beoplay M5 and Google Home
Answered (Verified) This post has 1 verified answer | 4 Replies | 1 Follower
tjn2000
tjn2000 posted on Fri, Dec 28 2018 1:44 PM
I am having issues connecting by Beoplay M5 to the google home app.  I have the latest speaker software showing in the in the B&O app and the speaker has been set to Chromecast enabled. I have a Beosound 2 with voice assistant and a Beoplay M3 already linked but the M5 is not showing at all in the app.  The speaker works if I use Spotify connect and I can use airplay with no issues.
I am wondering if there is a way to hard reset the speaker to see if it's recognised.  I have manually added it to my WIFI network and it is bluetooth enabled.  Every other speaker I have added just appears in the app ready to pair but not this one!
Any help would be greatly appreciated.
Hiort
Sweden
Answered (Verified) Hiort replied on Mon, May 27 2019 3:12 PM
Verified by DMacri
DMacri:
Is there some hidden setting in the google app or the B&O app to get these two devices to play together?
I have a similar set of devices but have no problems to play using Google Assistant built into my Beosound 1 MKii.
There is no hidden setting,
Try to powercycle the M3 and remove from Google Home. Then add again.
/C
DMacri
United States
DMacri replied on Mon, May 27 2019 1:43 PM
I'm having the same type of issue with my M3. I can connect to it using my iPhone through airplay or google connect, but when I ask my Google Home Mini to play "Jazz" on my Beoplay M3, it responds "Playing your Spotify playlist called jazz on Beoplay M3", but there is no sound. The Google home app confirms nothing is playing. Is there some hidden setting in the google app or the B&O app to get these two devices to play together?
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, and ambio
Hiort
Sweden
Verified by DMacri
DMacri:
/C
Stan
Stan replied on Mon, May 27 2019 3:32 PM
I don’t use Google voice commands, but have a Chromecast audio that always seems to require some fiddling to appear on Spotify. I don’t think these problems can be blamed solely on B&O.
I’d follow Hiort’s advice.
DMacri
United States
DMacri replied on Wed, May 29 2019 1:42 AM
It took several power cycles and removals, but now it works! Thanks
Dom
Page 1 of 1 (5 items) | RSS
