Beocenter 2300 CD issue
Not Answered This post has 0 verified answers | 3 Replies | 1 Follower
mr_anders_son
sweden
mr_anders_son posted on Thu, Dec 27 2018 9:04 AM
I know we have cover this issue many times before.
But I can not find the nearest answer for this.
When I press play on CD it spinns for 2 sec then stops.
Is it the only way to replace the laser unit??
thanx.
BeoVision Eclipse 55"...BeoLab 18 as FRONT....BeoLab 4000 as REAR....BL19 SUB....BV5 2xHDMI....BV7-32 MK3....BC6-26....Beosound 9000....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H8....H6 90´s Rose Gold edt....Form 1....U70...
mr_anders_son
sweden
This type!?
https://www.ebay.co.uk/itm/CD-Laser-Pick-Up-for-Bang-Olufsen-B-O-Beosound-BEOCENTER-2300/302663807553?hash=item46782b3241:g:LMMAAOSwurVZkCAn:rk:8:pf:0
Peter
Siemianowice Sl., Poland
Peter replied on Thu, Dec 27 2018 12:07 PM
I keep this repeating but before laser replacement you should be sure that nether laser lens nor CD are dirty.
Someone said that if glass in your cuppoard becomes dirty after some time the same happens to you laser lens.
mr_anders_son
sweden
Peter:
I keep this repeating but before laser replacement you should be sure that nether laser lens nor CD are dirty. Someone said that if glass in your cuppoard becomes dirty after some time the same happens to you laser lens.
I have clean it.
And got it work....but when I change to Radio and back to CD it spinns 2 sek then Stop. If I just touch the lens, not glas) it works againHuh?
Page 1 of 1 (4 items) | RSS
