Beolab 3500 sound troubles
Not Answered This post has 0 verified answers | 34 Replies | 4 Followers
DinoD
DinoD posted on Fri, Dec 14 2018 3:40 AM
Hey guys,
just received a BL3500, but there seams to be a strange problem, speakers has clicking/ticking sounds.
any help would be greatly appreciated.
Stefdachef84
Hi Steve, thx for the swift reply.
Type:1601
Serial: 18673469
Item:1160111
Sw: 2.0
Thx & KR Stefan
Stefdachef84
Type:1601
Serial: 18673469
Item:1160111
Sw: 2.0
Thx & KR Stefan
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Thanks Stefan,
This is a mk.1 Beolab 3500, so a specially wired cable is needed for this speaker (please choose the mk.1 cable option here): https://soundsheavenly.com/airport-express/155-2345-ipodtvairport-express-to-beolab-3500-mk2-cable.html#/2-length-1m/63-beolab_3500_version-mark_2
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Stefdachef84
Thank you for your assistance. I actually habe a comparable cable (7pin) is it still likely that your cable will solche the issue?
Could you provide also a shorter cable (I would like to fix the bluetooth device right in the Back of the beolab.
Thx and KR Stefan
Hi Stefan,
This cable wiring ins unique, no other 5 pin or 7 pin cable will work unless it is specifically wired for Beolab 3500 mk.1.  The cable is the cause of the issues that you reported in your post.
You can see the correct cable and the length options available in the link that I posted above.
Steve.
Page 3 of 3 (35 items) < Previous 1 2 3 | RSS
