For Home Entertainment Via LG’s 2019 Line-Up of OLED and Flagship UHD/LCD WiSA Ready TVs
Click here. - Click here.
LG TV line for March / April, these things get HOT. We write about LG 4K TVs 2019 lineups - HDMI 2.1 - eARC system, - Audio accessories - WiSA. If you have news now, write. Thanks.
Peter Pan: WIRELESS TECHNOLOGYThe wireless technology has reached a level that meets B&O's requirements for a perfect onesound experience. BeoLab 18 is equipped with the B&O's Immaculate Wireless Sound conceptis a mix of design, technology and wireless sound quality. The key to sound quality is WiSA-technology that works in the wireless U-NII 5 GHz spectrum, so there is always a stable signal. WIRELESS FREEDOMEnjoy wireless sound and grab the chance to decorate your living room without restrictions. A wireless BeoLab 18 setup requires only one power cable per. loudspeaker and thus free of allspeaker cables. Just focus on how the speakers best compliment your interior design. LG explains: WiSA USB dongle is a wireless audio protocol so you can connect WiSA compatible speakers wirelessly for a LG OLED 2019 display. The current implementation supports up to 5.1 surround. In the LG TV there is a new user menu from which to set up WiSA speakers. To get started you have to buy this USB LG WiSA dongle.
Good afternoon Peter,
Before investing in Beolab Wisa receivers and cabling. I would wait until the WISA LG TVs are available and read the reviews published to see how well their system works. If their surround processor is very basic such as Loewe, you may be disappointed.
Regards,
Jean
Reviews? There won't be many or any reviews that go into any depth on the LG WISA capability.....
Will be down to users / early adopters to take the plunge and provide some feedback.
Peter Pan could do the test for us ๐
Millemissen:Peter Pan could do the test for us ๐
Except that would set him back about 11.000dkk in Receiver1 boxes and cables
...or just let your B&O dealer do it - now that you are so sure, that he will get LG/OLEDs in the shop.
I am wondering: The WISA specification use the term "line of sight" for the range,- 10m.
The patch antenna in the USB stick will be situated behind a solid sheet metal plate (the chassis) pinned up against a wall. How exactly is that going to work and what kind of range can be expected?
Good luck with that!
it will be seamless, like all wireless technologies!
Not!
The dongle will always end up behind the sheet metal. This is how its done in the Avant,- two antenna cables are connecting to the antennas in front of the sheet metal, - see the difference ? Even this solution is not always good enough!
