Arm for Beogram 4000
michaelmaurice
Posts 21
Silver Member
michaelmaurice Posted: Fri, Nov 23 2018 7:45 PM
Does anyone have an arm for the Beogram 4000 or even just the connecting part for the cartridge?  Even an arm for a Beogram 4002 will do as it can be made to fit.
sonavor
Texas, United States
Posts 3,091
sonavor replied on Fri, Nov 23 2018 9:27 PM
Is your tonearm broken or is it just the cartridge connector that is broken (very common with the Beogram 4000). If it is just the cartridge connector then why waste ruining another good arm when you can just buy a new tonearm cartridge connector from Beolover's parts?
-sonavor
michaelmaurice
Posts 21
Silver Member
I'm looking into doing just that.  Do you know whether the plastic is as robust as the original?
sonavor
Posts 3,091
sonavor replied on Fri, Nov 23 2018 10:53 PM
I have used the Beolover part on two of my Beogram 4000 units and it is very sturdy. I don't know if B&O changed their material in that piece later because it seems to be an issue with the Beogram 4000 and not the turntables that came after it.
-sonavor
Page 1 of 1 (4 items) | RSS
