Beovision 5 Apple TV
Not Answered This post has 0 verified answers | 3 Replies | 0 Followers
MartinWVogt
MartinWVogt posted on Fri, Nov 9 2018 2:23 AM
hello, I have had my BV 5 for 14 years or so and had previously connected an Apple TV via scaler and hdmi component switch. Trying a repeat about 8 years later and I was wondering if anyone has experience with this. I assume the BV 5 can receive 1080i 50 ... thanks in advance
kallasr
Germany
Try 720p50...
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), no Subwoofer. Screen: Panasonic TX-P65STW60
Home Cinema: Beosystem 4, Beolab 7-2 (Center), Beolab Penta 2 (Fronts), Beolab 4000 (Rears) and Beolab 2. Projector: Sony VPL-HW55
Home Office: Beovision 10-40 on STB Bracket wall mount masterlinked to Beosound 9000 MK3 on horizontal wall bracket driving Beolab 5000 Speakers
Bedroom: Loewe TV with Beolab 6002 and Beolab 11 (all white, wall-mounted)
MartinWVogt
Thank you for your reply. It works using 1080i 60 on the scaler, I have been able to hookup Apple TV 4 with a converter. All works!
Stephanberlin
Hallo Herr Kallas,
wie funktioniert die Verbindung eines Beovision 5, MK 5 ( HD, 720) zu einem Receiver MR 400 von Entertain TV (Telekom )?
Ich bekomme ein Bild,aber keinen Ton. Hatte davor den MediaReceiver 303 angeschlossen, funktionierte wunderbar mit HD-Adapter und getrennter Tonübertragung mittels Cinch-Kabel. Nun kommt aber kein Ton mehr.... Haben Sie eine Idee?
Herzliche Grüße aus Berlin,
Stephan Friedberger
stephan-friedberger@t-online.de
Page 1 of 1 (4 items) | RSS
