Tonearm not work (up and down)
Not Answered This post has 0 verified answers | 4 Replies | 1 Follower
Ehsan
Ehsan posted on Fri, Nov 2 2018 8:12 PM
Hi, I have one (beogram 4002 type 5504). Today, after turning on, the arm moves automatically and moves forward, but the arm does not fall, and then I press it up and down, but it does not work. . The top button below does not work, please guide me which part is broken and I have to do what I do and what part to check. Thank you for your guide
Dillen
Copenhagen / Denmark
ONLINE
You cannot point your finger at the one specific component causing this.
There can be hundreds of reasons why the tonearm won't lower.
It will have to be diagnosed.
Is there a record on the platter?
Does the tonearm stop over the lead-in groove and just hover there?
Can you hear a solenoid click when the tonearm is supposed to lower?
Has a MMC cartridge been fitted on the tonearm?
Has the tracking force been set correctly?
Ehsan
Ehsan replied on Tue, Nov 6 2018 10:28 PM
Hi martin 2 Sensors on the circuit and the tonearm are healthy and the selenoid works with the multimeter test it is ok
Ehsan
Ehsan replied on Tue, Nov 6 2018 10:29 PM
2 Sensors on the circuit and the tonearm are healthy and the selenoid works with the multimeter test it ok
Ehsan
Ehsan replied on Tue, Nov 6 2018 10:31 PM
The problem is the big win
Page 1 of 1 (5 items) | RSS
