Volume control app Beolink NL/ML
Not Answered This post has 0 verified answers | 15 Replies | 1 Follower
gbraen
gbraen posted on Fri, Nov 2 2018 6:07 PM
Anyone know how to adjust volume on the Beolink NL/ML with the B&O app? The old Beoremote app I used before doesn't work anymore
Aussie Michael
Melbourne, AU
Just a guess but wouldn’t you use it as you would other devices in the app?
Beolink as I understand appears as a device nl ml converter. Is that correct ?
Other devices such as an A9 this is how you adjust the volume.
Tap the device and when you do the device background fills out the screen to show you it’s the selected device - you can also see in the black area too.
Then tap the ^
Then control the volume
elephant
AU
gbraen:
Does your BLC NL/ML have speakers attached to it ?
BeoNut since '75
gbraen
Yes, I use a Beolink Passive amplifier
elephant
AU
gbraen:
I am not sure we are talking about the same device ...
Here is the new App (I am on the beta)
In the middle of the 3 products is the silver BeoLink Converter ... it supports PowerLink but I do not have any speakers attached.
The screen is showing all 3 units are linked in a group if I go to this view, and click on each rooms little speaker icon (I.e. not the X as that disconnects that unit from the group) I get the slider option to adjust an individual set of speakers within that room
Is this the sort of environment that you are enquiring about ?
BeoNut since '75
Millemissen
Flensborg, Denmark
elephant:
gbraen:
I am curious there too.
Maybe he is refering to a BeoLink Passive (driving passive speakers) connected to the PL output of the Converter?
Millemissen
Flensborg, Denmark
elephant:
gbraen:
Or maybe the BeoLink Passive connected via ML to the Converter?
In the second case that would need an ir eye to be (volume) controlled....and can not be controlled via the app.
gbraen
gbraen replied on Sat, Nov 3 2018 10:43 PM
Yes, that's what I use.
Millemissen
Flensborg, Denmark
Thanks - and it does not appear in the device list like shown by elephant?
Millemissen
Flensborg, Denmark
@elephant
Is there maybe some setting in the converter for that - something that must be enabled?
gbraen
gbraen replied on Sat, Nov 3 2018 10:53 PM
elephant:
gbraen:
I have the same app. In the Beolink Group when I connect the NL/ML to my Beoplay A6 the volume control in the app doesn't appear on the NL/ML.. I have to use the volume control on the A6 to control the volume on the Beolink Passive(which is connected to passive speakers)
When I used the old Beoremote app I could use the volume control there for the NL/ML. But that app just crash on iOS 12.
gbraen
gbraen replied on Sat, Nov 3 2018 10:56 PM
Millemissen:
It's appearing, but no volume control
gbraen
gbraen replied on Sat, Nov 3 2018 11:01 PM
Millemissen:
@elephant
I asked on a facebook group, here is the answer:
 Set it to "BeoLink Converter with Speakers"
That will fix the issue
Millemissen
Flensborg, Denmark
Great - problem solved then!
gbraen
gbraen replied on Sat, Nov 3 2018 11:30 PM
Millemissen:
Don't know yet, haven't tried. Have no clue how to do it
Page 1 of 2 (16 items) 1 2 Next > | RSS
