Add Beosystem 3 MK1 to existing setup
Not Answered This post has 0 verified answers | 6 Replies | 1 Follower
BeoIce
Recklinghausen, Germany
BeoIce posted on Fri, Sep 7 2018 12:00 PM
Hi all,
to get 5.1 sourround sound with BL8000, BL6000, BL7.2 and BL11 I want to add a BeoSystem 3 MK1.
Before buying a BS3 I have some questions.
I have the following devices which I will connect via HDMI: DVB-S2 receiver, PS3 and Media Player
I want to connect a 65" Panasonic TV and an Epson Beamer, both HDMI inputs.
As BS3 MK1 only has DVI outputs, can I use a converter DVI+SPDIF to HDMI to connect TV and Beamer to BS3 outputs ? Which commands toogle between these two outputs ? I have both Beo4 and Beo5 but prefer Beo4 for daily use.
An IR-eye is already there for receiving commands for the T-T238 lintronic boxes.
BeoSound 9000 MK3, BeoLab 8000, BeoLab 6000, BeoLab 3500, LCS9000, BeoLab 11, BeoLab 7.2, BeoLab 7.1, Beolab 4 PC, BeoCenter 2300, BeoSound Century, BeoSound 8, Beosound 2, BeoVision 7-40 MK2 , BeoVision 7-32 MK3, BeoVision 6-22, BeoVision 4-42, BeoMedia 1, BeoCom 4, BeoLink 1000, BeoLink 5, BeoLink 4 & BeoTime
kallasr
Germany
Hello Martin,
DVI to HDMI adaptor is enough to get Picture to the TV / Beamer.
Why would you want to get sound to those? Sound is send to the Speakers via the BS.
Toogle command: FORMAT 0 (activates Cinema mode) - e.g. open second Output.
Please make sure the sw is up to date (BS), easy to check if center Speaker Can be deactivated in BS menu.
Best regards
Ralf
Living Room: Beosystem 4, Beolab 7-6 (Center), Beolab 8000 (Fronts and Rears) and Beolab 2. Screen: Panasonic TX-P65STW60
Home Cinema: Beosystem 4, Beolab 7-2 (Center), Beolab Penta 2 (Fronts), Beolab 4000 (Rears) and Beolab 2. Projector: Sony VPL-HW55
Home Office: Beovision 10-40 on STB Bracket wall mount masterlinked to Beosound 9000 MK3 on horizontal wall bracket driving Beolab 5000 Speakers
Bedroom: Loewe TV with Beolab 6002 and Beolab 11 (all White)
BeoIce
BeoIce replied on Fri, Sep 7 2018 12:39 PM
Hi Ralf,
you're right. I'm an idiot. Why should I send audio to TV/Beamer if I got the Beolabs Geeked
Send you a PM
BeoIce
BeoIce replied on Fri, Sep 7 2018 12:44 PM
Can I do anything wrong with a BS3 MK1 ? Is AST function a must have ?
Millemissen
Flensborg, Denmark
BeoIce:
No - if you want to stay in ML, that’s perfectly ok.
Hardly anyone use/has used AST.
However, if your screen is on a different wall than your tv, it’s nice to have this possibility.
But don’t forget - you will need a Beo5/6 for this.
https://www.bang-olufsen.com/~/mediaV3/Files/user-guides/AST/ast_supplement_english.pdf
BeoIce
Thanks MM, no need for AST here as the sreen comes straight down in front of the TV on the same wall.
I will also stay on ML as I don't think that I will buy NL devices in near future.
Do you know what the latest SW for BS3 is ?
beojeff
USA
Since you have some Lintronic code-converter boxes, you can connect a Lintonic box to the CINEMA port on the BeoSystem 3. You can program the Lintronic box to respond to the CINEMA ON and CINEMA OFF modes to send out IR signals (which you program into the Lintronic box) to control the projector, screen, lighting, etc. This makes a very smooth transition into the projector mode. You have control over the delays.There are instructions on doing this on the Lintronic site. You use the pins for DATA 1 and DATA 2. Note that you must cross some pins over to others to correspond correctly. You can do this using a breakout box.
Page 1 of 1 (7 items) | RSS
