my right BL8000 does not have any sound anymore.
Led turns to green from red when switching on.
The BL8000 is from 1993 Type 6801 I'm the first owner.
I have the service manual, took of the grid and took out the T20 torx screws from the amp modul.
But the modul wont come off , it apears to be glued.
Any idea how to get it out?
Thank's for your help.
"Glued" is about right - it's the goo that used to be the gasket between the module and the pole. It WILL come off simply lifting it, but you will need quite a bit of controlled force. Do not bang it, just keep the force applied and you will see it slowly starting to lift. Work slowly and try to avoid scrathing parts of the pole that will remain visible, as you will probably need to apply some kind of a lever.
For the actual problem, look for broken traces at the edges of the PCB (and anywhere that has been in contact with the disgusting mess that once was the damping foam).
--mika
Well done!
It seems very common that those particular traces develop a problem. While you're in there, you should remove the old damping foam and clean the boards - and do the other speaker as well as long as it still works.
I didn't put anything in there, but I never play very loud either.
I believe you can still order new foams from B&O, if you find a dealer that agrees to do that for you. Or just cut a similar piece of some acoustically soft foam.
And don't use ESD-foam. It's conductive.Oh yes, I have seen that ...
Do you have any Links for the right foam to use? As it appears to by possible to make fatal errors.
In the service manual I think the foam is listed as "damper", but there are no pictures of the place where they are and no picture of their original form.
Does anybody have this information?
Yes, I had the same problem.
Hello everyone, my very first post here.
I came to this thread by seeking out solution for exactly the same issue, one of my Beolab 8000 MK1 stopped working. It was the same trace and I rebuilt it.
I had to use the hair drier and everything worked.
While looking for the replacing foam I bumped into this eBay auction:
https://www.ebay.it/itm/Bang-Olufsen-Dampfungsmaterial-Dammung-BeoLab-8000-B-O-BeoPlay-Beo/154203121912?hash=item23e738e8f8:g:DSwAAOSwunNdpIEJ
What do you think guys? Should I buy 2 sets?
My best
GLOP
awesome, I was not really sure about it because the foam in mine looks black and less dense.
Any advise about where to buy spare parts (like the internal power section plastic support)?
Thanks for your kind support, gentlemen!
