New Member... Beovision 5 Screen Replacement
Not Answered This post has 0 verified answers | 2 Replies | 1 Follower
Justinonfire
Justinonfire posted on Thu, Jun 21 2018 8:25 AM
Hey Guys,
My first post! I searched through a bunch of old threads and translated a bunch as well but I couldn't quite find what I was after.
I've purchased a 42" Beovision 5 second hand, and I am looking at upgrading the panel. I few things I've figured out based on my searching:
* The panel inside my Beovision 5 is a 42" Plasma from Panasonic
* The panel is connected to a B&O motherboard of sorts..
* If I replace the panel and want the speakers to work, it will have to be connected to the B&O motherboard
My questions are:
* How is the panel connected to the motherboard?
* Is there an easy way to use the tv independently of the B&O electronics while still utilising the active speaker?
Any help would be appreciated. Thanks Guys!
Justin
bigbruggsy
Hello Justin,
I'm looking at doing the same thing. Did you find away of doing this?
Regards Damian
Beolab 8000 x 4
Beolab 1
Beolab 2
Beovision 7-40
Beosound 9000
Beosound 3200 x 2
Beosound Ouverture
Beolit 12
Relator
it is very easy. Buy an 40" or 42" Panel LCD. Change Panel .You dont need the old motherboard, just the speaker amplifier.
Page 1 of 1 (3 items) | RSS
