Order Beosound Core with IR?
Not Answered This post has 0 verified answers | 25 Replies | 3 Followers
stampfki
stampfki posted on Sun, May 27 2018 8:29 PM
dear all,
Where can I order the IR version?
Cheers
Pat
Pat replied on Mon, May 28 2018 9:12 AM
Any B&O dealer?
Roger
Norway
Roger replied on Fri, Jun 1 2018 11:23 AM
The Core has IR support now - but in a transition period, a store might have both versions available. The IR support is great news for BL5 owners, too.
Roger
elephant
AU
Roger:
Roger
How can we tell the difference between the two variants ? I seem to remember it’s not obvious ...
BeoNut since '75
chucky
chucky replied on Sun, Jun 3 2018 12:00 PM
No, I have 2 with IR. the DPL port is used but it still says DPL not IR.
I do have to say it works fine.
Roger
Norway
Roger replied on Mon, Jun 4 2018 7:40 AM
The old one became obsolete in mid-May (ie sold out from DK). The new one has the following type no. 3051 (replaces type no. 2797)
Roger
Aussie Michael
Melbourne, AU
I am confused.
Is the older one an IR Core?
And the newer one wasn’t IR but is now?
Thanks,
AM
Roger
Norway
Roger replied on Mon, Jun 4 2018 1:50 PM
IR was a feature requested at the very first dealer meeting after the launch, but it took its time before they got around to launching it.
But just to be clear as mud: the old one did not have IR, the new and current one does have it. It is a very nice device now for owners of the BeoLab 5 as they can use the latest technology to stream and listen to music.
Roger
Barry Santini
New York
Hi
How does that work when a Beolab 5 needs a CD signal to use the SPDIF input?
B
Millemissen
Flensborg, Denmark
Roger:
Roger
Very interesting indeed.
I suppose, that you mean the possibility to connect ‘via digital’?
Could you write a few words about how to connect and control - does a small guide exist?
Normally you will have to use the CD command to open the BL5 for the digital connection.
So....how are the BL5’s activted, when connected to the Core?
Do you have to connect via ‘digital out’ and via PL from the Core as well?
Millemissen
Flensborg, Denmark
Ouuups - Barry beat me on that question ;-))))
David
Dubai, UAE
Silver Member
David replied on Mon, Jun 4 2018 2:35 PM
I just set up a new Core with Beolab 5's. The speakers power up the Core is activated via the app. As far as I'm aware, no need for the digital out connections to be used in this configuration.
Sound quality is brilliant via Spotify!!
Barry Santini
New York
How is your Core connected to the BL5’s?
Roger
Norway
Roger replied on Mon, Jun 4 2018 3:34 PM
The recommended setup is to use the digital end-to-end signal from the Core to the BL5 (via optical-to-coax-converter) and at the same time use the PowerLink connection in parallel to maintain data communications. This setup avoids static noise.
Roger
Barry Santini
New York
Roger:
Roger
How does the BL5 get to know to use the SPDIF input?
Page 1 of 2 (26 items) 1 2 Next > | RSS
