Powerlink Speaker Cable - MK2 or MK3?
Not Answered This post has 0 verified answers | 2 Replies | 2 Followers
faithman1_21124
faithman1_21124 posted on Sat, May 19 2018 9:13 PM
Anyone know the difference between the MK2 & MK3 Powerlink Speaker Cables? I have ventage BeoLab 3000 Speakers connected to my BeoSound 5 & Beomaster 5. Does it make a difference - MK2 or MK3?
Millemissen
Flensborg, Denmark
https://www.beoworld.org/faq_view.asp?id=41
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Thanks MM!
I can't believe it is 6 years since I last updated that page for Beoworld Geeked
For Beolab 3000 speakers with displays, the simple answer is that the speakers won't work correctly unless you have the thicker fully-wired mk.2 cables all the way from the Beomaster to each speaker:-
https://soundsheavenly.com/powerlink-8-pin-din-connection/powerlink-mk-2-compatible-black-8-pin-din-cable-with-fully-wired-8-cores
Mk.1 or mk.3 cables are usually thinner (although not in every case) and they won't work with your speakers.
Any questions, please ask!
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Page 1 of 1 (3 items) | RSS
