Beolab 5 issue
Not Answered This post has 0 verified answers | 31 Replies | 2 Followers
Michael
Denmark
Michael posted on Tue, May 8 2018 3:37 PM
Hello other Beolab 5 owners or fellow Beoworld guys,
6 months ago I became the lucky owner of a preowned 2012 set Beolab 5, so far so good.
Now I'm having an issue with one of the speakers, that kind of "forget/loose" the calibration once a week, where the green light flashes but still plays.
I must power off the speaker and put in calibration mode again, wait to that's done and every thing works fine again, for at least maybe a week or so when the problem comes back.
Any good ideas or maybe someone has had the same issue, and found a fix or a repair from B&O?
Lets hear it from the experts.
Michael
Michael
Denmark
Nobody with the same issue at all, here in Beoworld?
Dante
Sao Paulo - Brazil
Dante replied on Fri, May 11 2018 5:11 PM
I never heard about this problem before, however, I'll give it a try...
In order to reset the calibration of a BL5 you have to press and hold the top plate button for a few seconds.
Possible causes:
1) someone at your place loves to press the top plate button and you are not aware about that. :-)
2) there is a problem at your top plate, which is activating by itself.
2.1) your top plate button is too sensitive.
3) another deeper problem in the circuits.
lawrencejmcook
Hi Michael, I’ve had this problem with one of my BL5s, but not the other.
At first I thought it was just forgetting the calibration, but then one day I was at home when it spontaneously started to calibrate itself. It did not complete the calibration, so I assume that’s why it flashed green intermittently the next time I turned my BV9 on.
(Temporary) cure was to disconnect it from the mains for about a minute, then reconnect and manually trigger calibration. It still forgets occasionally, maybe once a year.
I don’t know how hard is too hard to press the calibration button. If I merely touch it, calibration does not start.
Michael
Denmark
Thanx for your reply, this is something I'll try to work with, before B&O comes to repair it.
Michael
lawrencejmcook
Michael, did you ever get to the root cause of this problem?
Michael
Denmark
Nope, but my dealer will change the chassis with all the electronics of the speaker and hope the problem is gone.
lawrencejmcook
Good luck, sir.
phult
phult replied on Tue, Jul 3 2018 11:18 PM
Dear Lawrence,
I had the EXACT same issue with a brand new pair of lab 5 that I purchased back in 2007. I tried to get the B&O store where I purchased them to repair them under warranty several times but finally gave up because they were so rubbish at customer service.
Upon moving to a new house last year, I contacted B&O UK and to their credit once managed to get to a person of authority they took responsibility and eventually got them to repair the problem.
Unfortunately (for your) this involved replacing the main PCU "Brain" which I believe would have cost around 1800 pounds if not under warranty....
I suspect that the actual problem is a fried and much less expensive EPROM chip, but the way B&O repairs work they can't actually try and replace small individual parts - which frankly I understand.
So good news is you can fix this problem... bad news is its expensive if you have bought a second hadn't pair.... but good news (might be) that even once I had 'fixed the problem' I honestly did not hear any difference.
Best
Philip
lawrencejmcook
Philip,
How kind of you to write and share your experience - thank you.
I bought them new from a dealer here in the U.K. in 2013. Whilst they are now out of warranty, it was an issue I reported to them very soon after purchase.
But it happens so infrequently now, and getting service is so challenging from a time/effort/logistics point of view, I am not minded to pursue it until I stop travelling.
Thanks again for responding.
Kind regards,
Lawrence
Michael
Denmark
Latest update regarding my Beolab 5.
Yesterday I had a visit from my dealer, with the task to try and update the SW from 3.20 to the newest 3.30a on both speakers.
There was a little problem with the faulty speaker, but after 2-3 times the update was in place for both speakers. Now only time will tell if this is a fix, and I can save some money for not buying the expensive chassis replacement.
I'll get back with any news.
Cheers
Beobuddy
Utrecht, The Netherlands
phult:
This Eprom with the settings stored from each driver, can be taken out of the chassis and fitted on the new chassis. Which is a normal routine when a chassis is replaced.
If the Eprom fails, the settings can be downloaded via the serviectool as the these are stored under it's serialnumber on B&O's server and programmed on a new eprom.
Keep in mind that the fault isn't always caused by a "fried" eprom.
egj1975
Hi. This has nothing to do with the eprom or the chassis. This is a bad connection due to a bit of corrosion on a connector or a defective component on a small PCB thats under the "neck" of the speaker. The problem is that this bad connection tricks the speaker to think that you are pushing the top button on top and there for goes to calibration mode and than stays there. So when you arrive its blinking and waiting for a calibration.
Michael
Denmark
Okay that's interesting, do you know about a fix without buying a new chassis maybe?
/Michael
Michael
Denmark
Michael replied on Thu, Jul 19 2018 10:54 AM
Just a little update after 14 days since the update of my speakers, and still no problem with the speaker missing the calibrationSmile
Let's hope it stays like that and I've saved a lot of money.
/Michael
Page 1 of 3 (32 items) 1 2 3 Next > | RSS
