LUA variables on BLGW
Not Answered This post has 0 verified answers | 2 Replies | 2 Followers
Chris Hassell
London
Chris Hassell posted on Sat, Apr 21 2018 10:09 PM
Hi everyone,
I’m programming IF ELSE statements on my BLGW and want to use some variables to make some commands work. Apparently unless defined as local the variable are global by default. However I don’t seem to be able to share variables amongst macros. Anyone any clues??
BeoVision Eclipse 55”, Beolab 18s, Beolab 19s, Beosound 1, Beoplay P2, H3, BeoRemote One IR, BeoRemote One BT, Beoplay S8, Beosound Essence MkII, BeoTime
ChrisBerlin
Hi, do you get the if else-statement working in a macro? I tried it several times for programming brightness-depending scenes. But without success.
I want to switch the mode in blgw if brightness is higher than xxx
Do you have an example?
mjmedlo
ChrisBerlin:
Closest I’ve been able to do is use state updates from the panel
IE volume is 30.. closed drapes and blinds
Page 1 of 1 (3 items) | RSS
