Hi all,
I have noticed that there seem to be two different variants of NL/ML converter available looking at various images online; one including the PL, IR and AUX In sockets and another without these with blanking plates/covers in their places. Is the latter identical with the ports hidden behind the covers? Both seem to have the same Type and item no.
Ah, you know... A little B&O here, a little there
Thanks for the reply and info. Will the line-in work on the one with blanking plates in the same way as the other? Out of interest do you know how were they changed from being a beolink gateway? Was it an upgrade done in store, or upgrade over the internet? Any other way to tell apart from the covers? Cheers.
I just found this post showing the covers removed https://forum.beoworld.org/forums/p/4392/39340.aspx
