Multiroom Issues
Answered (Verified) This post has 1 verified answer | 37 Replies | 4 Followers
DavidSJones76
DavidSJones76 posted on Thu, Feb 1 2018 1:13 PM
Hey guys,
I have had several B&O and Beoplay speakers for a couple of months now. I have a Beosound 2, a Beosound 1, 3 x Beoplay A6, 2 x Beoplay M5 and 2 x Beoplay M3. I have them mostly in my living room with a couple of the other speakers throughout my house.
The problem I have is that almost everyday, I cannot get the speakers to all play together. Sometimes when I connect all of the speakers together using the app they all play together as expected, but most of the time they play then a speaker will stop then reconnect or they will all take it in turns to stop then reconnect. The worst part is that they sometimes don't even play in sync, so its like a massive echo going on.
When they work, I absolutely love the speakers, but I just cannot get them to play multi-room most of the time. Also, sometimes even when I play just one speaker it keeps cutting out.
I have tried many solutions such as turning off chrome cast or having chrome cast on. I have tried airplay too, but they keep having the same issues. I have tried 3 different routers and modems. I have even changed supplier for my internet. Nothing seems to work.
I have also set all speakers on a stable router channel (channel 11) with a static IP address. I have also set all the speakers to have priority over the internet bandwidth.
I just cannot get the speakers to work as sold. Factory resetting, switching the speakers off and on again, and rebooting the internet does nothing either.
Could someone please help me sort this issue please?
Thank you in advance for any support your give.
David
Fansastic
The Hague, The Netherlands
Verified by DavidSJones76
Did you try temporarily wired set-up? I had problems with Multiroom with my Moment which was the only device that was in Wifi mode. Despite strong wifi network I encountered fall out and sync problems. After reconnecting LAN (over powerline), all works well again. Maybe the total traffic for all devices over wifi is to heavy in your case.
Ulrike
Germany
Good luck for that!
Btw Chromecast issues are solved for all now:
https://9to5google.com/2018/02/01/google-play-services-update-fixes-chromecast-google-home-wi-fi-issues/
steve1977
mczac:
David,
from my personal experience BeoSound 1/2 wireless speakers are very sensitive to the quality of WiFi network. More over they don't buffer enough in case of a temporary collision on wifi spectrum. They work on 2.4GHz which is highly polluted by home appliances including microwaves. Plus most consumer routers may not have MIMO multiple receivers and transmitters to handle wireless streams independently increasing overall throughput. Other issue with BO Multilink technology is that it is not a multicast and transmission to the speakers is going independently, however as a feature request in addition to multicast, each speaker could have handled internet music source independently such as TuneIN or Deezer. You can eventually optimise your wireless coverage with additional base station and selecting appropriate channels using wireless diagnostics or expensive wifi spectrum analyzers. However where it is possible I strongly recommend to replace wireless with wired network.
Anyone has insights, why B&O does not include AC and 5Ghz receivers into their BS1/2. it feels an absolute requirement for a premium wifi device. even the ATV has this.
Historically, b&o has always included very outdated wifi receivers (eg, beolit came with G standard, which even at launch was outdated for a decade).
it feels like the very wrong area to save money as it heavily impacts user experience.
hope there will be a change for future wifi devices.
w5bno123
London
steve1977:
These are the specifications for the BS1/2 and other new NL wireless products.
Ethernet
10/100 Mbit
Wi-Fi
WLAN 802.11 b/g/a/n - 2.4 GHz and 5 GHz
Bluetooth
4.0 (Classic and BLE)
Line-in
1 x mini-jack.
Impedance for Line-in is approx. 10 k Ohm
Mains connector
Shaver plug
CB
> You are Here <
CB replied on Sat, Feb 3 2018 9:42 AM
DavidSJones76:
after having to reset the router the problems all returned.
Each time I reset mine, my wireless BS35 isn't able to find the network again. I have to unplug/plug it to main just after.
Will a static address solve this?
DavidSJones76
Hi guys,
I have wired most of my speakers in to the router and this has appeared to solve the problem for now. However, I have a few speakers I cannot hardwire in such as the Beoplay M3. I can live with that, but upstairs I have an A6 and BS 1, which still do not sync and drop out. I can't hardwire either of them, because of the distance between them and the router. Would you suggest power lining them or using a wifi extender upstairs then using an ethernet to the extender plug?
@CB I found when using an old Bose system that giving the speakers a static IP address solved many issues so maybe give that a try. I have all my current B&O speakers on a static IP with as much bandwidth as possible. Hopefully with the speakers now wired instead of wireless it will solve the problems I have been having.
Thanks for all the support guys. It is much appreciated.
David
mczac
mczac replied on Sat, Feb 3 2018 1:28 PM
please refrain from using wireless wifi extenders. PowerLine extenders are now capable of delivering speeds up to 1.2Gb/s.
w5bno123
London
Hi David
I would use powerline adaptors where necessary, they just work and your multiroom experience will be vastly improved. You just now everytime you go to use it Music will play. B&O are addressing the WiFi issue as we type.
If you need to connect your M3 you’ll need a USB-B micro to RJ45 adaptor cable and then you’ll be able to hardwire this as well.
Best wishes
Stuart
DavidSJones76
OK, I will take your advice and use a power line connection. Could someone recommend a decent power line adapter? I don't really know what I am looking for. I would need two for the upstairs speakers.
Thanks for the advice about the M3 speakers. Ill get a micro usb to RJ45 for those ones.
Thanks guys.
David
Hiort
Sweden
Hiort replied on Sat, Feb 3 2018 2:56 PM
DavidSJones76:
Thanks guys.
David
Recommend D-Link DHP-701AV.
I use several in my house.
DavidSJones76
Thanks for the suggestion.
I've now ordered a power line system for the upstairs speakers, some more ethernet cabling, and some micro usb to rj45 cables. That way I should be able to wire all my speakers in to the network and eradicate the issues i've been having.
Ill let you know if it works.
Thanks for all the support and advice once again
David
Hiort
Sweden
Hiort replied on Sat, Feb 3 2018 5:37 PM
Im also using my Poweplugs to stream 4K movies from my NAS to AppleTV 4K. Works super. I get around 100 mbps throughput Smile
DavidSJones76
That gives me a lot of hope that the powerline will work for upstairs then.
I won't find out until tomorrow, because that's when I get my delivery. I am determined to sort this issue out.
Thanks for the response.
Best wishes
David
steve1977
w5bno123:
Ethernet
10/100 Mbit
Wi-Fi
Bluetooth
Line-in
1 x mini-jack.
Mains connector
Shaver plug
That’s exactly my point. Why not even AC in a product that was just released 1-2 years ago. N standard may be ok, but ATV and other devices operate at AC for years...
DavidSJones76
Hi guys,
Just an update. I have wired all my speakers now, including power lining upstairs. At the moment, they are all working as expected and desired now. So, thank you everyone that contributed, it has really helped me resolve my issues.
Take care,
David
Hiort
Sweden
Hiort replied on Mon, Feb 5 2018 5:55 AM
DavidSJones76:
Hi guys,
Take care,
David
Good news Smile
Page 2 of 3 (38 items) < Previous 1 2 3 Next > | RSS
