BV5, Eclipse and: Scart cable quality impact on picture quality?
Not Answered This post has 0 verified answers | 7 Replies | 0 Followers
BeoET
BeoET posted on Thu, Jan 11 2018 10:31 PM
Strange question, I know, but:
- We’ve ordered the Eclipse 65. It was to be delivered and installed tomorrow, but the local dealer called me today and said that B&O have shipped the Sound centre and the panel to France instead of to Norway!! The dealer had only got the floor stand... Maybe it’s one VIP here at the BeoWorld-forum that B&O needed to prioritise ? ;-)
- In our preparation to move our BV5 to our glass house (BV5 will be replaced by the Eclipse), I had to cut the existing SCART VIVANCO HQ cable from the STB to the BV5 in order to replace it with a 10m (full-wired) Scart cable. The STB is placed one floor below (basement), and it will continue to deliver cable tv signals to the BV5 in the glass house adjacent with the living room.
- When testing the new 10m Scart cable (and some other standard short ones) between the STB and BV5, it seems to me that we experienced a sharper/better picture quality before, with the VIVANCO HQ cable. I’ve of course tested that BV5 still gets RGB signal from the STB as before through the scart cable, but:
—-> Can it really be that the picture quality it is noticeable better/worse with different scart cables, as long as they are all full wired and deliver RGB signals to the TV? Or is it just imagination?
(Since I had to cut the VIVANCO HQ cable in order to pull the new 10m scart cable through the hole between the living room and the basement, I no longer have a HQ cable to compare with)
BV Eclipse 65, BV5, BS Core, BL5, BL8000, BS9000, Beolit 12, A1, A2, P2, H8, H9, E8
kallasr
Germany
For Scart cables there can be better quality with better cables - I experienced the same in the past. For HDMI cables (at least short standard lengths) I have not seen differences in picture quality.
Ralf
Beosystem 4 with Beolab 7-6 on table stand (Center), Beolab 8000 (Fronts and Rears) and Beolab 2. Screen: Sony 55W905A. Beocenter 2 AO integrated via Beolink ML/NL Converter. Beosystem 3 MK I with Beolab 7-2 on table stand (Center), Beolab Penta 2 (Fronts), Beolab 4000 (Rears) and Beolab 2 driving a Sony VPL-HW55 projector. Beosound 9000 MK3 on horizontal wall bracket. Beosystem 7000 with Beolab 5000 Speakers. Loewe TV with Beolab 6002 and Beolab 11 (all white). Beocenter 6-26 white on motorised stand. In storage: Beolab 5000/Beomaster 5000.
Keith Saunders
Little Ann, Hampshire, United Kingdom
BeoET:
It's not you imagination. There can be quite large variations in picture quality and the factors which affect it most are:-
  • The screening in the cable itself. This can be the biggest factor
  • The way the cables are terminated in the SCART plug
  • The quality of the SCART plug itself
Regards Keith....
BeoET
BeoET replied on Fri, Jan 12 2018 9:25 AM
Thanks Keith and Ralf, I will go by our local B&O dealer today and see if they have an old HQ Scart cable that I can borrow - just to evaluate if there actually is a deteriorated picture quality in the Scart cable I've pulled.
I would like to have as good PQ in the BV5 as possible, even though we will not use the BV5 that much going forward. At the other hand, it's not very 2018 to try to get hold of a 10m HQ Scart cable...
BeoET
BeoET replied on Fri, Jan 12 2018 9:32 PM
BeoET:
Just to fair with B&O: Checked this again today, and it turns out that it was the shipping company (UPS?) that was to blame. B&O have sent a new panel and soundcentre - cross my fingers and look forward to next Friday :-)
Stones
Stones replied on Mon, Jan 15 2018 11:55 AM
May the length of the cable also influence the picture quality?
Keith Saunders
Stones:
Yes, the length of the cable certainly will influence the quality. The cable lengths should always be kept as short as possible.
Regards Keith....
BeoET
BeoET replied on Mon, Jan 15 2018 12:30 PM
Our local B&O dealer lent me a hi-quality 5 m Scart cable so that we could test that against the 10 m long Scart cable I have pulled through the wall. We couldn't see any (noticeable) difference between the two, so we'll stick with the current cable. I'm glad that I didn't need to search for and buy a new HQ Scart cable for this purpose (not very 2018'ish).
I think 2 issues fooled us to believe that the PQ of our BV5 had been better than it actually was with our original HQ scart cable:
1) We might have been too often in the B&O store lately - have started getting used to the PQ of the Eclipse...
2) When working with the cables behind the BV5, we've pulled the BV5 a bit closer to our seating position, thereby making the low resolution more visible.
Looking forward to Friday - new Eclipse being installed!
Page 1 of 1 (8 items) | RSS
