A1 echo with mic / Sound Setup on Mac
Answered (Not Verified) This post has 0 verified answers | 10 Replies | 1 Follower
Dartmoorwal
Dartmoorwal posted on Wed, Dec 27 2017 9:27 AM
Anyone else having trouble setting the A1 to work with a MacBook or PC when using it as a microphone and speaker for telephone calls or FaceTime / Skype?
I can set the audio to come out of the A1 and it seems the mic works, of a fashion, but the person at the other end says they can hear themselves echoing.
I have the A1 connected to the USB port.
Aussie Michael
Melbourne, AU
Dartmoorwal:
I haven’t tried but I will check and see
Yendys
Sydney
Yendys replied on Fri, Dec 29 2017 10:59 AM
My A1 works well on WhatsApp and messenger calls. It has the latest version installed
Dartmoorwal
Thanks Yendys.  Is the A1 connected via USB?  Have you changed settings in "Sound" options on your mac/Pc? If yes, what are Output and Input settings?
Many thanks
gallager
Dartmoorwal:
Something similar happened to me. Have you found a solution to your problem?
Barnett
Yendys:
It worked fine for me too until I updated my version of the Messenger's Apps.
gbhouse
gbhouse replied on Wed, Dec 16 2020 10:23 AM
It works well. Thank you buddy for sharing this.
Dartmoorwal
No solution, but seems no longer happening.  Sorry nothing scientific!
riyasen
I was facing same kinda issue with my Macbook pro 2020, i searched a lot on the Internet then finally fixed it after updating the mac.
Technologywell
But it is working well for me for one years...
kuyttendaele
Have been connecting the A1 though USB to iMac/Macbook Pro/Lenovo portable all without problems. On Windows you have to select the “BeoPlay A1 handsfree” in order to have the microphone working.
Karel.
Page 1 of 1 (11 items) | RSS
