Form 1 foam pad drawing
Not Answered This post has 0 verified answers | 13 Replies | 4 Followers
Mikael
Sweden
Mikael posted on Mon, Oct 1 2012 6:08 PM
Hi, I won an internet auction the other day. It was a pair of Form 1 headphones. Since they (as do many) miss the foam pads they went cheap. I emailed one of the sponsor companies that used to sell the B&O restoration kit. But it seems it is no longer available. So I'm thinking why not try and make my own. Trouble is I don't have any reference to start from. So do any of you guys have Form1 with the pads intact and are willing to take close ups and make a drawing? I saw online that some guy actually did retrofit Form 2 pads with good sounding results but that looks wrong I guess. And does not solve the prism like comfort foam piece above each element. Best regards, Mikael
Beocenter Overture | Beolink passive | CX100 | CX50
Rich
Orlando, Florida, USA
Rich replied on Tue, Oct 2 2012 5:15 PM
I have Form 1s which were purchased from Lee's shop last year.  Lee's shop had restored them with the B&O kit so the pads are in perfect shape.
How can I help?
Mikael
Sweden
Great! Since the kit is obsolete I'm thinking of making a drawing of the original foam pads and headrest supports. So I suppose accurate measurements of the two foam pieces on each side. Then some close-up pictures of the same items. Hopefully this could end up as a type of tutorial how to make your own.
Regards,
Mikael
Cleviebaby
Exeter, United Kingdom
Mikael,
I have a pair of Form 1s with relatively new pads attached that you can borrow to use as a template. If you pm me your address, I'll post them to you.
Cleve
Rich
Well, let me do a first draft here.
The piece that sits on the ear is essentially a rectangle.
42 mm up and down
40 mm front to back
7 mm thick
The density of the foam that sits on the ear is a bit less dense than a pair Sony headphones I have sitting here on my desk.  The piece that sits above the ear is even less dense.
That piece has a cross section very similar to a stylus.  See two posts down.
13 mm at the base
15 mm tall
Tapers down to about 6 mm at the top, which is rounded
35 mm front to back
Rich
A second view
Rich
And a sketch of the piece that sits above the ear.  See how it has the cross section of a stylus (inverted)?
Rich
Rich replied on Thu, Oct 4 2012 12:21 AM
Cleviebaby:
Mikael,
Cleve
Very generous offer of Cleve.  I suggest you take him up on it, if for no other reason to "feel" the density of the foam.
Mikael
Sweden
Cleviebaby:
Mikael,
Cleve
A very kind offer indeed! I plan to first find sources of suitable foam material. I will get back to you after that.
Mikael
Sweden
Rich:
42 mm up and down
40 mm front to back
7 mm thick
13 mm at the base
15 mm tall
35 mm front to back
Thanks! Exactly what I was looking for. Next up is trying to find suitable foam material and make some tests cutting it to shape. I was thinking buying bigger foam pads and then cutting them down to size. But if I find the stuff as raw blocks that would even be better. Suggestions are welcome ofcourse.
boreades
Restauration project, certainly not perfect but very comfortable...
Philippe
Jamian
OREGON, USA
Hi
I got the dimensions off this forum, created hollow geometry and 3D printed in a flexible materialCool I covered the ear pads in fabric, using a technique similar to the CX100s; pinching the material in small slots at the corners. I have tried a few geometries for the head pads. The ones shown are the best so far, but could be more flexible. Shame the 3D printing material is not black.Wink
Love = My  Beomaster 1001 + Beovox 2700
wokbelly
Midwest USA
You don't have a file of this? id like to send it to a friend of mine so hed print me a pair for my form ones since i don't have a 3d printer
Jamian
OREGON, USA
Jamian replied on Mon, Dec 13 2021 2:50 AM
Hi. I am not sure if I still have this file hiding somewhere. I still have the headphones. To be honest, the first attempt is not that great. They are not comfortable to wear for a long time. I want to redesign the parts with more flexibility, when I get the time. 3D tech has come a long way since 2015 :). If I find the files, or conjure up new ones. I’ll post to this thread in the future.
Page 1 of 1 (14 items) | RSS
