Wireless Penta project
This post has 27 Replies | 1 Follower
leosgonewild
Helsinki, Finland
Posts 2,323
Silver Member
leosgonewild Posted: Sat, Nov 25 2017 3:38 PM
I’ve been planning these for a while, and finally they are done.
Each are fitted with a ICEpower 50asx2 inside. The crossover is split, so each crossover is fed with a dedicated channel. I mounted an aux input on each, so that each speaker only receives one channel.
Then I have mounted a chrome cast on each, and grouped them. So now they are truly wireless and multiroom capable.
Just waiting for new surrounds for the midranges.
Big SmileLets have a Party !!!Big Smile
leosgonewild
Helsinki, Finland
Posts 2,323
Silver Member
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Sat, Nov 25 2017 4:26 PM
Outstanding! A very cool update to a classic. I take it you're using one channel of the amp for the woofers and the other for the tweeters and midranges? Kind of what audiophiles call vertical biamping with passive xovers.
I think B&O should take a lesson from you, considering their speakers are all active, why should you need a TV or Audiomaster to connect them to, I think the market for stand alone stereo speakers like this would exist.
Jeff
Johan
Bolsward, NL
Posts 427
Johan replied on Sat, Nov 25 2017 5:49 PM
Leos that’s really cool! Did you put the amps inside the cabinets?
Johan
Bolsward, NL
Posts 427
Johan replied on Sat, Nov 25 2017 5:51 PM
Is there no problem with heat generated by them?
leosgonewild
Helsinki, Finland
Posts 2,323
Silver Member
Amps are inside the cabinet. Just below the bass reflex. Heat goes upward, so I think there is no problem. But for safety there is a fire extinguisher two meters away for now.
Basstard
Posts 59
Basstard replied on Sat, Nov 25 2017 8:25 PM
Perkele Beer
Mikipidia
Posts 2,078
ONLINE
Mikipidia replied on Sat, Nov 25 2017 9:19 PM
this looks awesome! well done! did you happen to take any pictures while modding this?
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Sat, Nov 25 2017 9:25 PM
leogoeswild:
Do you have a thermal sensor you could run through the port and attach to the board/heatsinks temporarily to see? It's fortunate that Class D amps don't produce the same amount of heat as AB or even worse, class A space heaters.
Jeff
leosgonewild
Helsinki, Finland
Posts 2,323
Silver Member
I don't have a thermal sensor.
The amplifier is mounted vertically inside, and there is quite much space above it. I can atleast not feel the speaker getting warm in any way on the outside or in the bass reflex tube. If there was any heating problems I should feel the tube getting hot.i only have a few pictures, I'll post them from my iPad soon.
Otherwise I have been using them for a few days now, and they are working perfectly.
Total cost of the project was 160euros.
leosgonewild
Helsinki, Finland
Posts 2,323
Silver Member
And after changing to an android phone I now have an app that lets me use my wireless Pentas as an alarmclock Lets have a Party !!!
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Mon, Nov 27 2017 7:42 PM
Well, being it's a bass reflex speaker, the harder you work the speakers the more airflow over the amps!
Jeff
Johan
Bolsward, NL
Posts 427
Johan replied on Mon, Nov 27 2017 8:10 PM
Play Kool and the Gang!
leosgonewild
Helsinki, Finland
Posts 2,323
Silver Member
Small update about heat: no fire yet 😂
Johan
Bolsward, NL
Posts 427
Johan replied on Wed, Dec 20 2017 9:00 PM
Thumbs Up
OK Leos, then it is time now to try 'Fire' by Red Hot Chili Peppers Stick out tongue
DeaconBlue2016
Posts 76
Very impressive - is there anyone in the UK who can this?
DeaconBlue2016
Posts 76
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Thu, Dec 21 2017 6:13 PM
leogoeswild:
Bravo my man, bravo! An excellent project and a good result. I hope you get years of pleasure out of them. Yes - thumbs up
Jeff
Peter Pan
Posts 2,051
Peter Pan replied on Wed, Dec 27 2017 11:00 AM
Bravo  leogoeswild - I'm waiting for pictures. Yes - thumbs up
_________________________
leosgonewild
Helsinki, Finland
Posts 2,323
Silver Member
Added a google home mini, so now I have voice control as well.
Very happy with the setup now Big Smile
stampfki
Posts 138
Awesome!
BTW: what happened to your 7.4 Beolabs as fronts?kicked them out ?
leosgonewild
Helsinki, Finland
Posts 2,323
Silver Member
I sold them a long time a go. They did sound wonderful tho Smile
leosgonewild
Helsinki, Finland
Posts 2,323
Silver Member
Peter Pan:
Bravo leogoeswild - I'm waiting for pictures. _________________________
I did a second rebuild today. Here are pictures of placement of the 50asx2, wiring, and input.
Took some video footage, so will put a video of it up soon if the footage is sufficient.
tph
Denmark
Posts 161
tph replied on Tue, Jan 15 2019 8:38 PM
I had the pleasure of listening to these the other day. Pretty amazing!
— Tuomas | Bang & Olufsen | Bang & Olufsen Create
leosgonewild
Helsinki, Finland
Posts 2,323
Silver Member
Fitted powerlink RJ45 connectors the other day.
Picture and picture of schematics.
The person who made the schematic can take credit by commenting with a $-sign Big Smile
cyborggarfunkel
Posts 1
Wow. Finally I found that post. I am interested in a ICEpower 125. Do you have y idea how to connect the RJ45 cable to the P102 port. I can't find y information about it. That would be wonderful.
leosgonewild
Helsinki, Finland
Posts 2,323
Silver Member
Send me a PM. I have a 250asp lying around Wink
leosgonewild
Helsinki, Finland
Posts 2,323
Silver Member
The information about RJ45-P102 is literally in the last post before you said you can’t find it Stick out tongue
Page 1 of 1 (28 items) | RSS
