How to contact Penta 1 with Beocenter 2300?
Answered (Verified) This post has 1 verified answer | 11 Replies | 2 Followers
stanpan
stanpan posted on Fri, Nov 10 2017 2:10 AM
Hello!
I want to contact  Penta 1 with Beocenter 2300 or Beosystem 8000. ( i prefer 2300)
The problem is that  missing powerlink in Penta 1  (if i want to use with 2300)
Now i use from pc, but in this case the display not work.
How to possible that the music from pc(3.5 mm jack) and the penta display will also work with any device
(   8000 and / or 2300)
All the best!
Steve
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Hello Steve,
Yes, you can get the Penta mk.1s working with a newer system like the 2300, with the displays working.
You need a pair of short Powerlink to Speakerlink adapters (costing approx. £35 GBP for the pair including shipping). These will be approx. 20cm long and one will fit underneath each Penta speaker to connect to the Line and Speakerlink sockets.
You then just need a couple of Powerlink mk.2 cables (one cable for each speaker) to connect from the Powerlink outputs of the 2300 to the adapters under each speaker:-
http://soundsheavenly.com/powerlink-8-pin-din-connection/23--pl2-black-.html
Please feel free to get in touch via my sponsor link below and I will be pleased to advise on building the adapters for you.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Sounds Heavenly are proud to sponsor the BeoWorld forums!
Hello Steve,
Steve.
stanpan
Hi!
Thank your reply and solution!
I have powerlink cables for 2300.
How to know that Mk 1 or Mk2?
Best regards!
Steve
Hi Steve,
Unless you have a multi-meter to test that all 8 pins are connected, there isn't an easy way to prove that you have a mk.2 cable.  However, you can if the cable ISN'T a mk.2, as if it is less than 4mm thick then it isn't fully wired.  Hope that makes sense? Erm..
Steve.
stanpan
Hi!
The cable cca 2mm.
So i need to buy mk2 cable.
I see You have mk2 cable.
2 pieces
https://www.soundsheavenly.com/powerlink-8-pin-din-connection/23-powerlink-mk-2-compatible-black-8-pin-din-cable-with-fully-wired-8-cores.html#/length-3m
Right?
And 2 adapters and will be work fully.
Can you give some discount for the cable/adapter package?
best regards
Steve
Hello Steve,
Yes, I have the fully wired Powerlink mk.2 cables here, then you also need the adapters which can be custom built for you on request:-
Steve.
stanpan
Ok, i will buy, and thank you.
One more thing, i see in forum this configuration. Its wrong?( twin cable one for din one for line socket)
http://archivedforum.beoworld.org/forums/t/28352.aspx
Idont need to use line in socket?
Hello Steve,.
When the adapters are correctly wired, they will give display data to the speakers using the Speakerlink (4 pin) socket and audio to the speakers using the RCA Line socket.
Steve.
stanpan
Ok, thank you.
In this case the audio from pc go to 2300 aux (jack to din) then PL mk2 cable then  adapter for penta din socket.
Right?
Many thanks for your help!
Steve
Hi Steve,
Yes, that is correct.  Here is the PC to 2300 cable: http://soundsheavenly.com/bang-olufsen/67--trs-5pd-.html
Steve.
stanpan
Hi!
Thank you!One more last thing, Please link the  powerlink-speakerlink adapter! f not in stock, i will write for you on your site.
On the next week i will buy both.
best regards
Steve
Hi Steve,
The Powerlink to Speakerlink adapters aren't on my site, I build these to special order.  Please contact me via via sponsor link below for a quote and for details of how to order these adapters and I will be pleased to help.
Steve.
Page 1 of 1 (12 items) | RSS
