Recap List needed for BM, BC and BC CD 4500
Not Answered This post has 0 verified answers | 8 Replies | 1 Follower
Tomvdw
Tomvdw posted on Mon, Jul 3 2017 8:14 AM
Hi all,
as I got a complete set of the 4500 range, I would like to do a recap on all of these ones.
Does anybody have a list of needed caps - maybe already a shopping cart ?
Thanks / Kind Regards from Münster
Tom
sonavor
Texas, United States
Contact Dillen on this forum for recap kits. He is your best source for the components you are looking for.
-sonavor
Bram
Boxtel, Netherlands
Bram replied on Fri, Jul 7 2017 1:14 PM
Hi, I´ve done the same recap last year and have an excell sheet with all the elco´s if you still need it, plus the order list from mouser. Do you have the manuals?
Greetings, Bram
Tomvdw
Tomvdw replied on Mon, Jul 10 2017 11:45 AM
Hi Bram,
sounds good ! Please can you send the sheet to me ? Then I will order them directly.
I will check If all the manuals will be available and aould let you know, once needed.
Thanks a lot/Kind Regards
Tom
Bram
Boxtel, Netherlands
Bram replied on Fri, Jul 14 2017 1:12 PM
Hi Tom, I´ve sent you a private message, if you didn´t receive it can you PM me?
Greetings, Bram.
Beomichel
Hi Bram, is it possible to send me the excell list to do a recap on my beosystem 4500 please. Right channel isn't playing anymore. While the master is open to check the problem it's a good time to update the rest too. Thanks ahead. Michael
Weebyx
Denmark
Weebyx replied on Sun, Jan 20 2019 1:26 PM
Beomichel:
I would not just go ahead and change capacitors unless something is wrong. The reason your right channel is dead is almost 100% NOT because of capacitors. It is the mute relay or an amplifier transistor. It is easy to test, just plug speakers in Speaker 2 and see if there is sound then. If both channels work, it is the mute relay, if not it might be the amplifier. Also try the headphone connector to see if there is sound in that.
/Weebyx
Beomichel
Hi Weebyx,
Thanks for your reply.
I tried playing through Speaker 2 but got the same result. No right channel.
Its a problem i've been experiencing for some time. Before i just moved to cables around a bit, switched the system on/off after which i had both channels playing again. Now however i can't get anything out of the right channel anymore.
Can't check the headphone output as the system is already at the repair shop. Ill forward him your info.
He is refurbishing my M100's too. If you have any suggestions for that i would greatly appreciate it.
Thanks ahead!
Michael
Beomichel
Hi again Weebyx,
Indeed, there is no need to start changing caps etc as the only problem was some (6 actually) loos contacts which where resoldered.
Problem fixed.
M100's print plate needed quite some replacement parts. Plays on another lever now Smile
Cheers,
Michael
Page 1 of 1 (9 items) | RSS
