AirPlay 2
This post has 192 Replies | 10 Followers
christiank
Posts 56
That's odd! I can test on monday.
Sandyb
Posts 1,867
Sandyb replied on Sat, Dec 1 2018 7:26 PM
Christian, hi there
I've updated my PUC tables on both my BS4 and Avant (pre Android).
I can see the function list has changed on both TVs, but now post update the list looks like this
Home. green
Airplay Menu yellow
Home. 1
Airplay Menu 2
And nothing else - so the previous three functions have been overwritten by the above
And furthermore, the new Airplay Menu doesn't seem to work, whether I try and trigger using a long press on yellow button, or by bringing up the menu and pressing 2
Just thought I'd add my feedback
Sandeep
Millemissen
Flensborg, Denmark
Posts 13,637
You can only get into the AirPlay Screen from the Homescreen of the ATV....not when you are using an app.
mbee
Paris, France
Posts 1,768
mbee replied on Sat, Dec 1 2018 11:03 PM
I just tested the Airplay 2 update today, and I must say that I’m positively surprised : My Apple TV connected to a Beovision 8 (and NL/ML, which is not useful in AP2 setup) is almost perfectly in sync with my A9 mkII and Essence. No echo!
christiank
Posts 56
Hi Sandeep,
Which functions are you missing?
As Millemissen wrote, it does not work in all apps. See what happens on the Frontpage of the Apple TV. I have BV11-46 and it works like a charm. :)
christiank
Posts 56
Hi Sandeep,
1990
Posts 432
1990 replied on Sun, Dec 2 2018 9:43 AM
On my V1 the new PUC works, but a bit haphazardly. The yellow button needs a very long press? Or maybe the ATV is slow to load the AirPlay menu?
And I miss the lovely graphic buttons in the menu!
Millemissen
Flensborg, Denmark
Posts 13,637
For those, who use/have used the original Apple remote (mine is unpacked!):
Is this similar to how the play/pause button there works?
P.S. None of the apps that I tried gave me access (pressing the yellow button) to the AP2 menu from within the app - only from the Home Screen I can access this.
Which is kind of wierd and unhandy imo.
Millemissen
Flensborg, Denmark
Posts 13,637
How loooooong?
1990
Posts 432
1990 replied on Sun, Dec 2 2018 12:11 PM
I tested it a few times. 3 seconds it is. Love the look of the menu:
I have another question: will there be a sound delay using AirPlay 2 if I would *integrate* a Essence Mk2 or Core with my V1?
1990
Posts 432
1990 replied on Sun, Dec 2 2018 12:14 PM
Millemissen:
Yes, behaviour is similar as with the Apple Remote. The Apple Remote also doesn't give you access to the AP2 menu from within apps.
christiank
Posts 56
Short press on yellow should be enough
1990
Posts 432
1990 replied on Sun, Dec 2 2018 12:28 PM
Before we had very nice graphics to the right of the Home and Play/Pause options. They got lost in this new PUC-version. Hope we can get them back.
Furthermore: the yellow but now only pauses, but can't be used to send a Play command. Very strange. The Play/Pause button on the ATV remote does still both pause and play.
Here's a good explainer of all the extra functions of the ATV Remote:
https://www.youtube.com/watch?v=sHCazOY5vyU
1990
Posts 432
1990 replied on Sun, Dec 2 2018 12:34 PM
Sorry for these multiple posts - I'm testing it all a bit (love a bit of spare time with wife and kid away from home Stick out tongue
There is no need for the AP2-menu within Apps because it is accessible within the Audio-menu during playback of content. (Off course, this will cause sound delays, you preferably you should use BeoLink for multiroom BeoVision-content).
Sandyb
Posts 1,867
Sandyb replied on Sun, Dec 2 2018 2:02 PM
Agreed, exactly the same behavior at my end
Airplay menu only comes up on Apple TV home screen
Millemissen
Flensborg, Denmark
Posts 13,637
So, why did they/Apple make that menu?
Sandyb
Posts 1,867
Sandyb replied on Sun, Dec 2 2018 2:23 PM
Not sure - though i have retested the BR One now again, and finally got it to work i.e. bring up the menu from within an app.
Not perfect - one long press on the yellow pauses the video, a second long press brings up the Airplay menu.
Maybe it will get better, i.e. menu brought up with one long press, but as yet it requires 2 presses at my end.
Now that we're talking about PUC functions - perhaps the most useful function missing from the PUC table is the ability to bring up the info screen, as someone mentioned above. That info screen / menu allows Airplay (re) direction etc, and is useful at times.
It would be great if that can be added to the PUC functions - probably best achieved using the Info button on the BR i would suggest.
Otherwise, as it stands the current PUC functionality is very limited. Fine in so far as it goes, but no more.
Millemissen
Flensborg, Denmark
Posts 13,637
Wht do you miss?
Sandyb
Posts 1,867
Sandyb replied on Sun, Dec 2 2018 3:09 PM
As stated, being able to bring up the info screen is useful. It shows the episode / video description, allows Airplay control etc.
The BR doesn't have the voice control built in to the native remote.
Nor does it have the video scrubbing back / forward that the native remote does.
If I used the Apple TV more, these omissions would bother me more.
But let's not pretend the current PUC implementation for Apple TV is anything other than very basic.
And the current PUC functions can be achieved using CEC.
But you know my expectations for PUC inclusion in future products - I'd like to see it included, as it can be a bit better than CEC, but doubt it will be. And in cases like the Apple TV implementation, it's no better than CEC.
christiank
Posts 56
But Sandyb, many functions are different depending on the app on Apple TV.
E.g there's some stupid golf app than you can't get out of with the back-button. You have to press green. In another app, yellow is pause and a third it gives you the information of the current programme. And lastly, many of the functions on the ATV remote are bluetooth, and can't be learned to PUC functions. That really does not have anything to with B&O's implementation, but more that app developers that are not aligned.
Sandyb
Posts 1,867
Sandyb replied on Sun, Dec 2 2018 7:11 PM
I don't disagree, and it doesn't bother me (i.e. a basic implementation).
I maintain that i have my doubts over whether PUC will be implemented in a future BV or sound centre designed for use with 3rd party TVs.
PUC is nice in so far as it goes, but as you imply, is a bit limited, and voice and apps are increasingly relied upon as a control interface.
Millemissen
Flensborg, Denmark
Posts 13,637
Sandyb:
1: One push down of the navi key of my Beo4 brings up that menu just fine - I don’t know how the BROne reacts.
2: OK - if voice control is important to you - personally I couldn’t care less!
3: ‘scrubbing’ is just a very fast forward/backward search - personally I never missed it.
There are only basic controls on an ATV - nothing complicated to contol there.
You take the CEC, I’ll keep PUC 😉
Sandyb
Posts 1,867
Sandyb replied on Mon, Dec 3 2018 12:00 AM
Once again you have misinterpreted my point.
I'd prefer them to retain PUC, i just think there is a pretty reasonable chance they don't.
For reasons explained numerous times.
You are correct though on that info window, i didnt realise it can be accessed.
The broader point remains though - i fear they will regard IR as unnecessary, given CEC is more prevalent, and the increasing industry shift to voice and apps.
My thoughts around this are merely a riposte to the previous discussion about possible specs to a future sound centre type of product, where PUC was assumed to be included. I wouldn't make that assumption. Many posters act as if life cannot continue without PUC, but things move on, and IR i fear will decline in importance, a process which has already started in my view.
But like you, i'd have a preference that it was retained.
Millemissen
Flensborg, Denmark
Posts 13,637
This kind of discussion always tent to be rather academic.
We have no idea how things will work out, what they will end up doing.....
.....and no influence either.
All I can say is, that in my case PUC solutions work.
My son is using CEC (non-B&O tv) - I would not say that that works well.....sometimes yes, but by far not always.
Maybe a combined solution will be the result - PUC for the SC and the connection and integration of the many (still) ir related devices, and CEC for connection to X-tv.
We’ll see what comes.
Sandyb
Posts 1,867
Sandyb replied on Mon, Dec 3 2018 9:19 AM
completely agree, all i am flagging is perhaps moderating expectations as to PUC inclusion, but i would prefer its inclusion.
I dont have any CEC control paths, but quite a few of my friends with relatively new equipment have managed to use their TV remotes to control the streaming boxes connected to their TV's, and soundbars.
So for all that PUC is a bit better, that may not be enough to guarantee its continuation.
jimcaj
Denmark
Posts 126
jimcaj replied on Mon, Dec 3 2018 9:42 AM
Is this possible?
Turntable->Riaa->M3(LineIn)->AirPlay2->Libratone Mini or other AirPlay2 compatible 3rd party brand device
Turntable->Riaa->M3(LineIn)->M5->A6 is working, but thats Beolink Multiroom. I’d think.
/ mike
Hiort
Sweden
Posts 2,630
Hiort replied on Mon, Dec 3 2018 10:33 AM
jimcaj:
Is this possible?
No, that is not possible. M3 (or any other B&O device) cannot initiate an Airplay stream.
jimcaj:
Correct. Its Beolink. No Airplay involved.
jimcaj
Denmark
Posts 126
jimcaj replied on Mon, Dec 3 2018 10:52 AM
Thanks Hjort! Tip: M5 on sale on Amazon.de
/ mike
egges
germoney
Posts 303
egges replied on Sun, Dec 9 2018 1:00 PM
cool thing they got it finally to work. works smooth to say siri/the homepod to connect kitchen-speaker etc. even appleTV is on sync now. one thing doesn´t work anymore here: my beolab 2000 in the bathroom via the nl/ml-converter doesn´t join an airplay-session anymore.
Wohnzimmer: BeoVision Avant 55", BeoLab 11, 12-2 und 12-3 für 5.1-Sound +  appleTV 4K und Philips BluRay-Player; BeoSound 2, BeoSound 3000 (fast nur noch Deko)////Schlafzimmer: BeoEssence MkII, BeoLab 4000 + Samsung 46"-TV////Büro: BLC NL/ML, BeoSound 35, Thorens TD320MkII, Samsung 32"-TV, WesternDigital 4TB-Server////Bad: BeoLab 2000; alles CAT7 verkabelt////Küche: M5 (drahtlos) plus diverse apple-Geräte (imac, macbook, ipads, iphones, timecapsule, watch)
Dyssegaard
Copenhagen, Denmark
Posts 219
Silver Member
egges:
Wohnzimmer: BeoVision Avant 55", BeoLab 11, 12-2 und 12-3 für 5.1-Sound + amazonFireTV, appleTV (4th. gen.) und Samsung BluRay-Player; BeoSound 2, BeoSound 3000 (fast nur noch Deko)////Schlafzimmer: BeoEssence MkII, BeoLab 4000 + Samsung 46"-TV////Büro: BLC NL/ML, BeoSound 35, Thorens TD320MkII, Samsung 32"-TV, WesternDigital 4TB-Server////Bad: BeoLab 2000; alles CAT7 verkabelt////Küche: M5 (drahtlos) plus diverse apple-Geräte (macmini, macbook, ipads, iphones, timecapsule, watch)
In order to join an Airplay session, Airplay for multiroom must be turned on in the settings for the speaker you are Airplaying to.
I have attached a screen shot from my M5. Please observe that this can result in synch problems between Airplay 2 sessions in general.
Best regards - Dyssegaard
Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K. Bedroom: Beovision 11-40, AppleTV 4. Home office: Beoplay M5. Kitchen: Beoplay M5. Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
Hiort
Sweden
Posts 2,630
Hiort replied on Thu, Dec 13 2018 3:33 PM
I have only been able to add BS1 and M5 to Apple Home app. App show my M3 and A6 but I cannot add them.
Anyone have any advice?
mbolo01
Annecy - France
Posts 1,769
mbolo01 replied on Thu, Dec 13 2018 9:36 PM
I have been able to add the M3, M5, BS1 and Core to the Apple Home App
EDIT: and the A6
CarJen
Posts 8
CarJen replied on Sun, Jan 6 2019 8:20 AM
Hello fellow B&O fans,
Do any of you have issues with Airplay 2 on Beoplay M5 after the release? - I can play one number and then it cuts off the sound. I use Tidal Hifi from iPad and/or iPhone. Reset has been done, but little good it did, unfortunately.
The issue is both when streaming only to the M5, but also when using both my BS 2 and M5. Pretty annoying.... 😏
/Carsten
Page 5 of 5 (193 items) < Previous 1 2 3 4 5 | RSS
