BeoVision 4-103 stand problem
Answered (Not Verified) This post has 0 verified answers | 12 Replies | 0 Followers
politician
politician posted on Mon, Apr 24 2017 6:58 PM
My BV4-103 is being a little odd tonight, and won't go up on its motorised stand when I turn it on, though the picture and sound appear as normal. I'm assuming the connection between the stand and the BeoSystem 3 has worked loose, but I can't find it, Where does it connect?
kallasr
Germany
ONLINE
Should be described in the manual of the Beosystem 3.
Ralf
Home Cinema: Beosystem 4, Beolab 7-2 (Center), Beolab Penta 2 (Fronts), Beolab 4000 (Rears) and Beolab 2. Projector: Sony VPL-HW55
Home Office: Beovision 10-40 on STB Bracket wall mount. Beosound 9000 MK3 on horizontal wall bracket driving Beolab 5000 Speakers
Bedroom: Loewe TV with Beolab 6002 and Beolab 11 (all white, wall-mounted)
zerocool143
Suggested by zerocool143
Can you check the back side of the TV and see under the TV if there is a blinking red light.
If there is, then there is an error with the stand. You must use the service tool software to remove that error.
Better call you local dealer and ask for support.
Cheers!
politician
Thanks for your very helpful response. I've had a quick look and cannot see a blinking red light. I've done a little troubleshooting with some telephone support from my friends at Lifestyle AV, and we think we've identified the problem: the cable connecting the BeoSystem 3 to the floor stand has frayed, so the command is not getting through. The challenge now will be getting hold of my dealer so he can come out and replace it.
politician
You were absolutely right — it was a software fault, with three red lights blinking underneath the TV. The problem is that my dealer cannot get the service tool to connect to the stand — it simply refuses to recognise it. We're starting to wonder whether the PCB in the stand has failed. Does anybody have any ideas how to solve this?
9 LEE
Eastbourne, UK
9 LEE replied on Tue, Jul 11 2017 7:24 PM
If the cable has frayed, maybe it's shorted some wires and nuked the PCB... Erm..
If it's basically a monster 7-40 stand, the PCB will be in the base, under the aluminium cover.  I'm at home so don't have access to the service manual, but that's (logically) where it would be.
Lee
politician
Thanks Lee! From what we can tell, the cable doesn't have anything to do with the problem: it's a straightforward software fault (the stand detected an obstacle and auto-locked). We just can't get the service tool to connect to the stand.
zerocool143
[/quote]
hrfKx[quote user="politician"]
Bro you need to force to load the software. I have encountered that before. Just try and give it a shot. Let me know if it helps.
politician
Thanks for the feedback. How would we do a "force load"? The problem is that the service tool is not recognising the stand (or vice versa) at all, so my dealer and I are at an impasse.
zerocool143
Just put check on the Force load and let it upload the software even if its not recognizing the stand. The trick is the force load should be check. Just try and give it a shot.Cool
Dellittef
thank you very much zerocool... i've never thought about this myself but it does seems to be legit. i haven't yet tried it but maybe im gonna come back with an update later. definitely gonna give it a shot but... right now i barely can do anything since i have to search for hgh pharmacy because of my health issues... that is why i wanted to ask you... would you mind if i am going to have some questions to ask you? thanks!
zerocool143
Yeah Sure! feel free to ask me questions. maybe I can give suggestions that might help you.
politician
Stand is displaying an error message again (which seems to happen about once a year). Should be easy enough to clear, as once we worked out how to do it, it took 10 minutes with the Service Tool on the previous two occasions. This time round, the red light is flashing twice rather than three times, so we're clearly in "error mode 2" rather than "error mode 3". Does anybody with access to BeoWise know whether this is resolved in the same way (i.e. clearing the fault using the Service Tool)?
Page 1 of 1 (13 items) | RSS
