LUA on BLGW
This post has 8 Replies | 2 Followers
Chris Hassell
London
Posts 394
Chris Hassell Posted: Mon, Apr 24 2017 11:16 AM
Hi all, I have my BLGW back up and running after moving house. With the capability to change commands to Lua code we can now create IF ELSE statements. So excited!! One button can now turn lights on and then off if they're already on!!!
BeoVision Eclipse 55”, Beolab 18s, Beolab 19s, Beosound 1, Beoplay P2, H3, BeoRemote One IR, BeoRemote One BT, Beoplay S8, Beosound Essence MkII, BeoTime
Seanie_230
UK
Posts 2,194
Great isn't it
One day I will self teach myself how to create drivers
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Chris Hassell
London
Posts 394
Have you done anything interesting with it yet @seanie_230 ? I haven't had a proper play yet but I did a generic lights on/off switch.
Carolpa
Posts 1,340
Carolpa replied on Mon, Apr 24 2017 6:49 PM
Chris Hassell:
I tried to read the setting temperature of the Nest Thermostate and increase the value +1. Didn't succeed until now. I can adjust it to a value, but I want to make a button to increase / decrease the settings.
boskonay
Posts 76
Any good 'starter' macros or code samples available?
I'd love to have timed events happen, conditional on button presses or other device states...!
Chris Hassell
London
Posts 394
So far I've just created the below as a global way of having an on/off light switch (when turning on I use a scene called 'standard'). Would love to create IF/ELSE statements using time, or time relative to sunset.
__________
function(event, engine)
local result = engine.query(event.area() .. "/" .. event.zone() .. "/DIMMER/*/")
if result[1].get("LEVEL") == "0" then
engine.fire(event.area() .. "/" .. event.zone() .. "/BUTTON/Standard/PRESS");
else
engine.fire(event.area() .. "/" .. event.zone() .. "/DIMMER/*/SET?LEVEL=0");
end
end
__________
mjmedlo
Posts 921
mjmedlo replied on Sat, May 6 2017 2:10 AM
Carolpa:
This may be coming to you already in the next updates. Big Smile
Carolpa
Posts 1,340
Carolpa replied on Sat, May 6 2017 5:02 AM
mjmedlo:
Carolpa:
Still it is a good case to learn LUA
ChrisBerlin
Posts 26
Hello,
I want to control lights brightness dependent with Lua, but it doesn’t work. I want to use my KNX-sonsor to set the mode setting dependent on the brightness. The outdoor sensor gives me a lux value displayed in the monitor. But I can not get it to read out the value so that if the value is above a certain lux value the mode is set to day (or light) and night (or dark). I tried it with Lua code but I cant get it work. I have to admit, that i am a total beginner
Here the code:
  local result = engine.query("global/Terrasse/_KNX_Group_Address/Helligkeit")
  if result[1].get("Value") > "30000"
  then
  engine.fire("global/Wohnung/VARIABLE/Tageszeit/SET?VALUE=Hell")
  engine.fire("global/global/SYSTEM/BLGW/SET MODE?mode=Hell")
  else
    engine.fire("global/Wohnung/VARIABLE/Tageszeit/SET?VALUE=Dunkel")
  engine.fire("global/global/SYSTEM/BLGW/SET MODE?mode=Dunkel")
  end
end
I got this error:
18-05-01 11:58:59 Event fired global/Terrasse/_KNX_GROUP_ADDRESS/Helligkeit/SET?VALUE=26462
18-05-01 11:58:59 Event fired global/Terrasse/_KNX_GROUP_ADDRESS/Helligkeit/SET_NONZERO
18-05-01 11:58:59 Macro fired global/Wohnen/MACRO/Test Macro Helligkeit
18-05-01 11:58:59 Error: global/Wohnen/MACRO/Test Macro Helligkeit execution error: Line 3: attempt to index field '?' (a nil value)
Anyone here an idea what i did wrong?
Christof
Page 1 of 1 (9 items) | RSS
