I have just been to a flea market where I bought a Beosound 2 player; I couldn't´t resist it... I bought another one a couple of years ago, and when I tried to get that working, I ran into the same problem:
When copying files manually to the SD card, the player won't play back the files. I somehow managed to install an ancient BeoPlayer on a XP PC back then, and it seems that it, apart from transferring the files to the card, also generated a (hidden) playlist file. It seems that only the tracks listed in this file is playable. The format of the file is semi-readable; I can see roughly see the formatting, but it is not a straightforward text file.
Has anybody succeeded in making a Beosound 2 play back mp3 files copied to the SD card?
I know that it is an old and impractical device, but it certainly has its own charm...
BeoNut since '75
