Bad linkeye at Beolink passive/ ML-MCL conv
Not Answered This post has 0 verified answers | 7 Replies | 1 Follower
Master123456789
Master123456789 posted on Sat, Mar 11 2017 10:16 AM
Hello
I have two beolink passive, the one is called Beolink Passive, the other one ML/MCL converter.
The beolink passive linkeye is very good, but the linkeye at ML/MCL is very bad. It only works when I point the remote direct into it. What is wrong? Is it the linkeye or the software?
TWG
TWG replied on Tue, Mar 14 2017 10:01 AM
Did you try to switch both ir eyes to check if the behaviour is the same on each unit? Did you install it yourself, maybe wrong soldering?
Guy
Buckinghamshire
Guy replied on Tue, Mar 14 2017 10:12 AM
Two other possibilities - both long-shots but worth checking:
- Is there dirt on the inside (or even outside) of the IR window on the faulty sensor?
- Is there a plasma TV in the same room as the faulty one - this has been known to cause interference with older IR eyes?
Master123456789
The bad linkeye is completely new, but I will try to switch them and see what will happen then! ;-)
Master123456789
And no plasma tv. ;-)
TWG
TWG replied on Wed, Mar 15 2017 9:27 AM
Where did you buy it? Is your ML/MCL installed permanently? If not, take it to your dealer with the bad eye and he should test it. Maybe it's not compatible, wrong type or s.th. like this?!
Master123456789
I do not buy anything from new. If it was a dealer I had called him immediately! ;-) And yes it is installed permanently - my things have to look nice! :)
TWG
TWG replied on Fri, Mar 17 2017 8:55 AM
Okay, than you have to do some work ;-)
- start with switching the Beolink eyes
- check the wiring
for example: http://archivedforum.beoworld.org/forums/t/35053.aspx
Here are many threads on the forum helping about wiring. Please use the search function.
Page 1 of 1 (8 items) | RSS
