I'm planning to buy Beovision 9 in next 2 to 3 months (moving to new appartment).
2 questions - isn't it too big for 55sqm living room ? plus what are the differences from MK2 till MK4 ?
Second option also was Beovision 4-65 with BeoSystem 3 but from purely esthetic POV BV9 is clear winner ... technically comparable ?
thx
Marek:I'm planning to buy Beovision 9 in next 2 to 3 months (moving to new appartment). 2 questions - isn't it too big for 55sqm living room ? plus what are the differences from MK2 till MK4 ? Second option also was Beovision 4-65 with BeoSystem 3 but from purely esthetic POV BV9 is clear winner ... technically comparable ? thx
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
Hi Marek,
here you will find an explanation from 9 Lee:
http://forum.beoworld.org/forums/p/20285/166249.aspx#166249
I had a BV9 for many years. It's a fantastic TV and it worked without any problems. The ACM-Camera automatically adjusts the Picture qualitity.
Digi
BV 14-55 mit BL 18, BL 8000, BL 2, BeoRemote One-BT, ATV 3; BS 9000 & BS Core & BS 4500 mit BL 12-3, BL 12-2, BeoLink 1000; BeoLine mit BC 2, BC 6000; BS 8; BeoVox CX100; BeoTime (analog), BeoTime (digital); Earphone A8; Beoplay H3 + P2
Michael: Marek: I'm planning to buy Beovision 9 in next 2 to 3 months (moving to new appartment). 2 questions - isn't it too big for 55sqm living room ? plus what are the differences from MK2 till MK4 ? Second option also was Beovision 4-65 with BeoSystem 3 but from purely esthetic POV BV9 is clear winner ... technically comparable ? thx Don't forget plasma looses brightness and quality over time. Not so sure it's a good investment anymore.
Well I'm not sure that's always true - I have a Pioneer Kuro 8th gen from 2008 that's been used more or less daily and the picture quality remains exceptional. Not 4K, or 3D or whatever of course, but a very good picture even by modern standards.
As for the BV9, it's a big object and of course not really up to date either but it's still (IMHO) a great TV and beautiful object in its own right - although I actually preferred (aesthetically) the BV5 since the curved 'frame' on the BV9 doesn't look quite as classy (IMHO).
MK I and II are HD-Ready (and therefore cheaper). MKIII and higher are FullHD and have the ACM (Camera inside frame).
MKIV has the newer AST sound option in the BS3.
Beobuddy:MK I and II are HD-Ready (and therefore cheaper). MKIII and higher are FullHD and have the ACM (Camera inside frame). MKIV has the newer AST sound option in the BS3.
BeoVision Eclipse 55"...BeoLab 5 FRONT....BeoLab 4000 as REAR....BV5 HD....Beoplay V1-40....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
