Moment User? Twonky Server has been removed from QNAP OS v4.3.x
Not Answered This post has 0 verified answers | 68 Replies | 3 Followers
kimhav
Malmo, Sweden
kimhav posted on Wed, Jan 4 2017 11:00 AM
If You are making use of Twonky Server from the QNAP App Center on their NAS then beware of that they have dropped the support for Twonky Server in the current beta v4.3.x and moving forward. Quoting a brief response that I got from the QNAP support after that I realized that Twonky isn't no longer combatible with the current beta:
"After 4.3.x, Twonky service is not available on NAS system. For DLNA service, we will suggest please apply the built-in DLNA service and install media streaming add-on app on App center for advanced management too."
Depending on what QNAP NAS you have, you can quickly overcome this issue by making use of the ContainerStation and run a dedicated Twonky Server to support the BeoSound Moment. The container solution dosn't add any significant overhead compared using the twonky server from the app center.
Carolpa
Sal:
I can confirm that the QNAP sees the Beosound Essence, Beosound A6, as well as my BV11 in the devices list o the scanned media receivers, but Beomusic doesn't show the renamed "QNAPServer" in the source list. Damnit B&O!
All Dlna servers switched on in my network are shown in BeoMusic (minimserver, twonky, kodi, Microsoft media player, jriver).
So it is to easy to blame it directly on B&o!
Check your settings!
Sal
California, USA
Sal replied on Sat, Jan 7 2017 7:18 AM
Carolpa:
Sal:
Checked and double checked. Maybe it is QNAP, maybe it is B&O but it is not working. But DLNA is DLNA, with B&O's track record with SW, I choose to believe it is BeoMusic which is the culprit. B&O themselves recommend Twonky. Can anyone with a QNAP device please advise?
I will graciously admit if it is my settings which are at fault here.
Carolpa
Sal:
Did you install: Media Streaming add-on on your QNAP (search for it on their website)
mbolo01
Annecy - France
Sal:
Sal - I don't think your settings are wrong.
I have the same issue with my A6. My QNAP is running both Twonky and QNAP DLNA server. While the BS Moment sees the QNAP server as well as the Twonky server in the list of media servers, the A6 only sees the the Twonky Media server through the BeoMusic app.
When using third party APP such as Media Connect app on IOS, I can see both Twonky and QNAP servers which is a proof that the A6 (and the BS 35) do not behave correctly.
@Carolpa: The Media Streaming add-on is used by the QNAP Music application to stream music to DLNA receivers which is not what Sal wants to achieve here. That said, I have the add-on installed, both the BS Moment and the A6 are listed as Media Receivers but the QNAP Music only sees the A6 as a possible receiver ......
To summarize: lot of inconsistencies between DLNA management for product of the same brand.
@Sal: We need to escalate to BeoCare before moving to the next QNAP, assuming we don't want to avoid adding the management of a virtual machine with Twonky inside, even in a light environment such container station
Carolpa
Still strange thinking it is a Beomusic issue if
Twonky, Kodi, Jriver, Plex, Microsoft Media center, Minimserver all DLNA servers and all are visible by Beomusic.
mbolo01:
Help me figure this out? Isn't this exactly what he wants. Or do I misinterpret something?
The Moment, Essence, BS35, Beoplay A6 aren't DLNA receivers/players? And he want to stream music from the QNAP server to these players, or.....?
His problem is Beomusic as DLNA controller doesn't seem to see the QNAP server. Does QNAP have a check box to switch on/off DLNA control of other brand controllers?
Millemissen
Flensborg, Denmark
All the servers, that I have on my network (on my (relatively old Synology NAS and on my Mac Mini) show up in Beomusic/Essence as well as in HomeMedia on my V1.
Never had any issues there.
I have changed my router recently - which did not have any negative effects either (my Essence is wirelessly connected).
I never tried the Twonky - why should I, when everything is ok with the other DLNA servers?
(Note: I don't have, need or want an iTunes library in my setup.)
That said - I might some day try the Twonky server, since it is highly configurable.
I would install it on my Mac Mini (which is running 24/7) and point it to the files on my NAS.
This way I would not depend on the support from a particular NAS or version of the NAS.
mbolo01
Annecy - France
Carolpa:
We are saying the same thing
Sal simply wants to browse is QNAP DLNA Collection from the the BeoMusic app but the QNAP DLNA server does not show up in the list when the Twonky one does and they both run on the same NAS, which is different than going onto a player such as the QNAP Music app and stream music to a a DLNA Receiver such as the A&, BS 35, etc....
There is no restriction in the QNAP DLNA server that I have seen so far
Carolpa
mbolo01:
Carolpa:
Does by any reason QNAP uses different ports than the usual Upnp ports? Or maybe the port is blocked for this program in the QNAP server!
Is the server set to be controlled by Sonos? They use a different port.
mbolo01
Annecy - France
From what I can see QNAP does not have any specific ports, nor restrictions.
I have done another test with my internet provider box, Android O/S + VLC app.
VLC is able to see and browse all DLNA servers I have on my netwrork, including QNAP and Twonky.
Finally I have installed the Serviio Media server on the same QNAP NAS and it is immediately available to the A6 through the BeoMusic App
To summarize:
Controller = Android ISP Box
Player = Android ISP Box
Server = All visible and usable
Controller = IOS MediaConnect App
Player = IOS MediaConnect App
Controller = IOS BeoMusic App
Player = BS 35 or A6
Server = All visible BUT QNAP Media Server
Controller = BS Moment
Player = BS Moment
Carolpa
mbolo01:
To summarize:
Renderer = Android ISP Box
Renderer = IOS MediaConnect App
Renderer = BS 35 or A6
Renderer = BS Moment
Interesting test!
But only in case of the BS35/Beoplay A6 you can speak for sure about "Renderer". In DLNA al the other could be "Players" (the controller= the renderer). So still it could be possible QNAP doesn't accept "other" controllers.
mbolo01
Annecy - France
Carolpa:
Correct, I have changed my post and replaced "renderer" with "player", sorry for the confusion.
I have not tested the renderer side as I don't think this is the issue that was raised initially, and the BeoApp music is no a DLNA controller as such but a B&O device controller only.
Sal
California, USA
Sal replied on Sat, Jan 7 2017 4:55 PM
Hi everyone and thank you for putting your heads together.
I’m as flummoxed as you all are. First, I moved to a QNAP TS451+ recently because I wanted an alternative to my always on 2010 Mac Pro, which was a waste for what it was actually doing (serving up music via Twonky, and acting as a backup file server) — though it did that splendidly -- it just took up a lot of space. Though looking back on it, having all the HDDs inside a flexible enclosure and full integration in my Mac environment was pretty sweet.
With the QNAP, I am very satisfied at the straight forward setup, small size, low noise and low power use, redundancy in RAID5, and native apps like Plex, Twonky, and others that my family uses, even when we're away from home.
In fact, this is so recent a purchase, that when I first read in this thread that QNAP wasn’t supporting Twonky any longer I immediately checked my return window with Amazon. Thankfully it is 1/31/2017.
I really didn't want to end up buying a device whose main pleasurable purpose for me — which is to serve up music to my Essence via Twonky — is now hamstrung by never having its software updated for fear of the loss of functionality for which I mainly purchased it. That being said…
What mbolo01 has stated is accurate. There is something inherent in the framework of either the BeoMusic App, or the implementation of the QNAP DLNA, which prevents the BeoMusic App from “seeing” the QNAP DLNA server as a music source.
I have rechecked my settings, and there is no other option I can think of that leads me to think that it is a server issue, as mbolo01 has found in his testing.
I have a rather large music library and I have indeed tried options (on the Mac Pro, and those available on the QNAP) like minimserver, serviio, firefly and even Plex, and what I’ve found is that Twonky ends up being the fastest implementation in the BeoMusic App. An example is that Plex, although being the most functional, takes time (provress wheel to load the next set of data) to scroll through the lists of artists and Twonky offers an index feature (sorting by ABC, DEF, etc) which helps to navigate to an artist quickly rather than having to scroll, since the BeoMusic App doesn’t have a search feature.
I really feel like I’m caught between a rock and a hard place with B&O & the Essence. I don’t want a Moment, and the Essence’s interface (the BeoMusic App), has two glaring weaknesses in my opinion: use ability for large music libraries is cumbersome, and its dependence on a 3rd party software which B&O has no influence over. So the customer experience can differ from user to user.
So, if there is a solution to this quandary and QNAP DLNA somehow ends up working, I fear that the user interaction through BeoMusic would be similar to what I’ve experiences with everything BUT Twonky. That is, it will be slow and sluggish.
I have four options:
  1. Never upgrade the OS of the QNAP and continue using Twonky
  2. Buy a 2-bay QNAP and use it ONLY as a Twonky Server for the Essence (and never upgrade the OS)
  3. Consider another NAS like a Synology (which doesn’t have Twonky) and hope that it’s DLNA implementation satisfactory through BeoMusic
  4. Bring out of the closet, my Mac Pro and start to use it again as a server
  5. Move to another system (see below)
In other threads, I have seriously contemplated moving to a dedicated music storage and streaming device like the Auralic Aries MINI (with a 2.5” HDD/SSD installed) which, for my use case would essentially be a hard disk based replacement for the Essence. I’d rather have my BL20’s connected via PL, and with a non B&O system, integration is lost, and I can’t use the Essense Remote Wheely to control the device.
Anyway, I’ll keep an eye on this thread and submit a ticket to BeoCare, knowing their response time with issues like this, I’m not holding out hope.
Millemissen:
I have to point out that B&O has placed itself in this position already by recommending TwonkyServer, which has weaknesses of its own. I contacted TwonkyServer and asked them about a search feature, they said that's B&O's problem. BeoCare said I should contact Twonky, so we're already depending on support from entities which don't seem to care about their customers. Why is B&O recommending something they don't have control over?
Additionally, MM is right, though. The simplest solution is indeed to run Twonky on an actual computer, which may be what B&O have intended, and which will likely be what I end up doing again - Right back to where I started. Stick out tongue Guess I need to learn something: If it ain't broke, don't fix it.
Sal
California, USA
Sal replied on Sat, Jan 7 2017 5:04 PM
One more update. I successfully installed Twonky within Containerstation on the QNAP and it worked. That is, it set up the TwonkyServer fine. The issue is that there is no way I can find to point TwonkyServer within ContainerStation to the directories where my music is stored. It appears that the directories that TwonkyServer makes available within containerstation are somehow sandboxed to within the ContainerStation files and can't be accessed by my Mac's file system or QNAP. Strange. Unless someone can help in that regard.
mbolo01
Annecy - France
Sal:
I think I can help. I just did it for myself and it looks ok.
1 - you have to enable Telnet (or SSH) on your NAS to connect with a terminal session
2 - connect as Admin
3 - identify the directory where your music collection is ("/share/CACHEDEV1_DATA/Multimedia/iTunes/iTunes Media/Music" in my case)
4 - go in the directory where the container directory files are located ("/share/CACHEDEV1_DATA/Public" in my case)
5 - in the ../Public directory, create a symbolic link named "Music" (for example) to the music collection: ln -s "/share/CACHEDEV1_DATA/Multimedia/iTunes/iTunes Media/Music" Music
6 - When creating your Twonky Container, in the Advanced Settings/Shared Folders, add a "Volume from host", browse the /Public directory, select the Music directory created in step 5 and name the mount point /Music (for example), hit enter to validate
7 - Create the Twonky Container
I now have a Twonky 8.3 running in a Container that has indexed my 35k track in a very fast time. running in // with the QNAP Twonky 8.2 app.
If QNAP DLNA server does not make the job, I'll purchase a Twonky License
Hope it helps
Sal
California, USA
Sal replied on Sat, Jan 7 2017 11:39 PM
mbolo01:
Sal:
Hope it helps
Thanks for your steps. I'm only superficially familiar with terminal and ssh, so I'll have to tread lightly with it.
I still have to say: this is a lot of work to get our expensive audio equipment working the way we want it to :-) Still frustrated at this whole ordeal.
Page 2 of 5 (69 items) < Previous 1 2 3 4 5 Next > | RSS
