Does anyone know what kind of speaker it could be?
https://www.certipedia.com/companies/174322/product_certificates?locale=en
https://fccid.io/MSIP-RMM-BOA-BeoplayM5
BV Eclipse 55 Brass - BL 18 Brass - BL 19 Brass - BL17 Black - BL 3 White - BS Moment - BS 2 Brass - BV Horizon 48 - BS3000 - BS 3200 - BS Essence MK2 - BL 4000 - V1 40 Black - V1 40 White - BLC NL/ML - H6 - H4 - E8 Motion - A8 Earphone - Beolit 12 - Beolit 15 - Beoplay A1 Green - Beoplay A3 White
Brigantinus:My dealer is not very happy with the sound, he even didn't want to give a demonstration. And after a demonstration i can understand him. You can compare the sound with a radio clock (i think it is designed for that kind of use in the bedroom). If you have the space A6 ist much better.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Library: A6, Beocom 6000 Bedroom: M5 Office: Beocom 2 Travel: Beoplay E8 2.0, Beoplay P2
egges: somebody was kidding you. it's exactly the same except for the soundsettings which are done in the Beoplay app
Spec does not include Tunein. Correct?
mine has TuneIn. it works fine as an alarm in the morning with one of my favorites from TuneIn. and i'm free to listen to another station than e.g. the Essence currently playing
Wohnzimmer: BeoVision Avant 55", BeoLab 11, 12-2 und 12-3 für 5.1-Sound + appleTV 4K und Philips BluRay-Player; BeoSound 2, BeoSound 3000 (fast nur noch Deko)////Schlafzimmer: BeoEssence MkII, BeoLab 4000 + Samsung 46"-TV////Büro: BLC NL/ML, BeoSound 35, Thorens TD320MkII, Samsung 32"-TV, WesternDigital 4TB-Server////Bad: BeoLab 2000; alles CAT7 verkabelt////Küche: M5 (drahtlos) plus diverse apple-Geräte (imac, macbook, ipads, iphones, timecapsule, watch)
egges: mine has TuneIn. it works fine as an alarm in the morning with one of my favorites from TuneIn. and i'm free to listen to another station than e.g. the Essence currently playing
So it does have a timer?
It has TuneIn, but you are not able to start that source from the device like the A6 with a short tap, you always need an app. Hope that a software update will fix this as I don't like to use a phone or tablet in the morning to start the radio in the bath...
It is unclear to me why this function is not implemented.
yes
try it again, marcus. with one finger only it doesn't work, at least two fingers you need. in the B&O video they take four fingers. i hope the top will get less coarsened with time, could be more fine
It does not start TuneIn...
So I understood that you can start TuneIn even if all other sources in the network are off, right? If I have the M5 playing TuneIn (and all other devices off) and then switch the M5 off (so that the power light goes dark) and then start the M5 again with a press on the top, the power light comes on and a plopping sound can be heard (like the A6 and A9) but no music :-( in the BeoMusic App you can see that TuneIn is not startet... Does this work with your device?
By the way, can you connect the BeoPlay app with the M5, after the last SW-Update I can't connect any more.
Thanks and best regards
Marcus
all works pretty well with TuneIn and the M5: alarms, with the e.g. A6, different stations simultaneously on the devices. Beoplay app has sometimes to be started twice: one for bluetooth connection, second for wifi. have all apps and the M5 the latest software? with the wheel i can change sources but can't switch stations within TuneIn
Played with one in store today. MY GOD THIS THING FEELS CHEAP. I thought that plastic feeling wheel at the top was just going to pop right off. Very unimpressed.
BeoLab 18's. Beolab 3's. A8. A9. A2. H7.
Severed_Hand_of_Skywalker:Played with one in store today. MY GOD THIS THING FEELS CHEAP. I thought that plastic feeling wheel at the top was just going to pop right off. Very unimpressed. -- BeoLab 18's. Beolab 3's. A8. A9. A2. H7.
BeoNut since '75
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
First thing I thought is that looks like a cheap mini version of my 5 year old Libratone speaker:
Severed_Hand_of_Skywalker: First thing I thought is that looks like a cheap mini version of my 5 year old Libratone speaker:
Actually, that looks better than the M5!
M5 is a strange beast. Both times I asked my dealer to demo the unit, the reckon they can't get it to work. Got the impression they don't want to demo it!
moxxey: Both times I asked my dealer to demo the unit, the reckon they can't get it to work. Got the impression they don't want to demo it!
If they can't demo that, they can't demo any of the new NL-speaker systems either!
Basicly it works just like the rest.
P.S. Tell them that the easiest way to demo it, is to use the bluetooth connection.
