I have a Beomaster 4500 receiver. I'm going to use non-B & O in the wall speakers. How do I power them.
Not Answered This post has 0 verified answers | 4 Replies | 1 Follower
Melech
Melech posted on Sun, Nov 27 2016 5:31 AM
I was told I needed a in line amp? Help
elephant
AU
Since I can't read all of the post's title I am not sure what you are trying to connect to :-
BeoNut since '75
Millemissen
Flensborg, Denmark
That is easy!
Just plug them in - use the right speakers plug, though.
Melech
Melech replied on Sun, Nov 27 2016 2:30 PM
I have in the wall speakers. Using it in a home office. They are real good in the wall speakers but are not B & O and are not powered. Will they work or do I need to use an inline amp. Also in connecting a non- B & O turntable do I need anything or can I just connect it together with the appropriate cables?
Millemissen
Flensborg, Denmark
The BM4500 has an amp built-in.
Just use the speakers wire from the in-wall speakers - as I wrote you will have to mount the right plugs.
You can find the User Guide here:
http://www.bang-olufsen.com/da/product-support/sound-systems/beosystem-4500
If you want to connect a non-B&O turntable, this must have a RIAA-amp or you must use an external.
Again - you will need the right plug for connecting it to the Master.
Page 1 of 1 (5 items) | RSS
