BV14 and Beovision Horizon - any feedback?
Answered (Verified) This post has 4 verified answers | 457 Replies | 14 Followers
Guy
Buckinghamshire
Guy posted on Sat, Oct 8 2016 4:30 PM
Considering that both the BV14 and Beovision Horizon have been out for several weeks there's been very little feedback on this forum!  Does anyone have either and is in a position report how they have got on?  Or is everyone hanging on for the anticipated new TVs next summer?
I am in the market for a new B&O TV and would like to purchase this side of Xmas.  I have been very disappointed with 'android' in the past (albeit with a tablet), hence I am particularly interested in the new android interface and whether the SW runs well?
Anyone?
BartS
Answered (Verified) BartS replied on Thu, Oct 27 2016 1:00 PM
Verified by kuyttendaele
I have just been informed that there indeed is a bug in the audio-part of the software and that this will be rewritten. As the connection with the Beoremote One BT concerns; there should not be a connection issue. B&O thinks the problem should be within the TV and that the TV should be shut off from power for a time (+ half an hour). Afterwards the remote should not have connection issues anymore.
Sjengie
Verified by Sjengie
I have been using the BV 40 since launch and I do have many software glitches which none of the updates have solved yet.
I am also waiting for update to connect to my wireless speakers eg beosound 1. The TV stops at times without any reason, the TV guide crashed all the time. Sometimes you switch it on and the remote is bklocked after which you have to unplug and plug it again. I can go on and on ...
Dealer says updates are coming and it will take time. Is okay for me but my wife hates it.
Worst is that netflix app does not work on the beovision.
My dealer told me that B&O recommends to use apple tv. Some argue between B&O and Netflix.
Unbelieveable. I have a subscription with Netflix, I should be able to use it.
The TV itself looks very very nice but is too buggy if you ask me.
I give it another month or so, if the Android glitches are not solved soon I will return it.
good luck
BartS
Answered (Verified) BartS replied on Sun, Mar 12 2017 4:19 PM
Verified by boskonay
As said before: at this stage you have to contact your dealer. He passes your serial number through to B&O and subsequently the update will be transferred to your Beovision. I guess it wil take a few weeks before the update is automatically transferred to all the NG Beovisions.
TEL
Taunton, Somerset UK
Answered (Verified) TEL replied on Tue, Mar 14 2017 8:00 PM
Verified by TEL
Many thanks Sandyb - I'll probably go ahead with Avant NG 55 later this week
BartS
BartS replied on Thu, May 24 2018 7:45 AM
.... after the update there seems to be a faster response to commands from the Beoremote.
kuyttendaele
My BV14 updated this evening too... Remote seems a bit more responsive!
Karel.
kuyttendaele
After the firmwareupdate the BeoOneRemote BT seems, as previous stated, to react faster. The startup-time of the set still takes ages. But that's probably related to the TPVision hardware.
Anyone in the the ability to have a the release notes?
Karel.
Fansastic
The Netherlands
New software update available
BV Eclipse 55 Brass - BL 18 Brass - BL 19 Brass - BL 3 White - BS Moment - BS 2 Brass - BV Horizon 48 - BS3000 - BS 3200 - BS Essence - BL 4000 - V1 40 Black - V1 40 White - BLC NL/ML - H6 -  H4 - E8 Motion - A8 Earphone - Beolit 12 - Beolit 15 - Beoplay A1 Green - Beoplay A3 White
PK
PK replied on Wed, Feb 6 2019 7:45 AM
have you tried it? any news or improvements? Smile
Fansastic
The Netherlands
Not yet, will do this tonight. I do not expect major improvements. Although the picture quality seems to improve after each update, think that is mainly in my mind.
Hope the android OS is a little faster, the stability is good since a long time. The response of the TV could be better.
luciajon
luciajon replied on Mon, Aug 31 2020 12:56 AM
The software experience has been poor, though seems much more stable now. As for the remote, i dont regard it as a step down particularly (and i have an infra red version for my lounge TV)..
..i haven't had the problems described above, the residual problem i have is that the source specific functions sometimes don't get sent to the TV on startup, so requires reselecting the source on the remote, and its fine from there. Generally though the TV software doesn't seem to crash very much at all, once in the last few weeks for me...
.i suspect thats as much an for iphone and Android thing. If you have low patience for quirks as described, then you will have to think about the above....reviews of Sony TVs also mention software crashes.....
dayoff2017
Suggested by dayoff2017
My Horizon is pretty stable. Some weeks ago I deleted every single App that was even possible: the reaction of the device is now remarkably faster. I even deleted some Android-services (some of them were reinstalled, nothing went wrong).
Chromecast: well, not too bad, but for how long in future?
Netflix: a shame...
Youtube: not too bad
Sky: ...
Over all I wish we had more "longtime-support" for a several-thousand-€-device, but still happy with av-qualities for both video and gaming....
Page 31 of 31 (458 items) « First ... < Previous 27 28 29 30 31 | RSS
