BV14 and Beovision Horizon - any feedback?
Answered (Verified) This post has 4 verified answers | 455 Replies | 14 Followers
Guy
Buckinghamshire
Guy posted on Sat, Oct 8 2016 4:30 PM
Considering that both the BV14 and Beovision Horizon have been out for several weeks there's been very little feedback on this forum!  Does anyone have either and is in a position report how they have got on?  Or is everyone hanging on for the anticipated new TVs next summer?
I am in the market for a new B&O TV and would like to purchase this side of Xmas.  I have been very disappointed with 'android' in the past (albeit with a tablet), hence I am particularly interested in the new android interface and whether the SW runs well?
Anyone?
BartS
Answered (Verified) BartS replied on Thu, Oct 27 2016 1:00 PM
Verified by kuyttendaele
I have just been informed that there indeed is a bug in the audio-part of the software and that this will be rewritten. As the connection with the Beoremote One BT concerns; there should not be a connection issue. B&O thinks the problem should be within the TV and that the TV should be shut off from power for a time (+ half an hour). Afterwards the remote should not have connection issues anymore.
Sjengie
Verified by Sjengie
I have been using the BV 40 since launch and I do have many software glitches which none of the updates have solved yet.
I am also waiting for update to connect to my wireless speakers eg beosound 1. The TV stops at times without any reason, the TV guide crashed all the time. Sometimes you switch it on and the remote is bklocked after which you have to unplug and plug it again. I can go on and on ...
Dealer says updates are coming and it will take time. Is okay for me but my wife hates it.
Worst is that netflix app does not work on the beovision.
My dealer told me that B&O recommends to use apple tv. Some argue between B&O and Netflix.
Unbelieveable. I have a subscription with Netflix, I should be able to use it.
The TV itself looks very very nice but is too buggy if you ask me.
I give it another month or so, if the Android glitches are not solved soon I will return it.
good luck
BartS
Answered (Verified) BartS replied on Sun, Mar 12 2017 4:19 PM
Verified by boskonay
As said before: at this stage you have to contact your dealer. He passes your serial number through to B&O and subsequently the update will be transferred to your Beovision. I guess it wil take a few weeks before the update is automatically transferred to all the NG Beovisions.
TEL
Answered (Verified) TEL replied on Tue, Mar 14 2017 8:00 PM
Verified by TEL
Many thanks Sandyb - I'll probably go ahead with Avant NG 55 later this week
Sandyb
Sandyb replied on Thu, Feb 23 2017 9:10 PM
i updated mine tonight......before the release date was showing as 18-Jan, now showing 27-Jan.....version number QM153E 0.3.0.112.....(BV-14)...not sur if that helps......
ThatGuyFromDenmark
Thanks Sandy, that clarifies a lot.
kuyttendaele
@ThatGuyFromDenmark
Here's a screenshot after the update of this week.
Karel.
Aussie Michael
Melbourne, AU
Has the week 20 / march update been rolled out?
Aussie Michael
Melbourne, AU
Week 10 even
Sandyb
Sandyb replied on Fri, Mar 3 2017 11:05 PM
towards end of next week....
Aussie Michael
Melbourne, AU
Thanks sandy
mr_anders_son
sweden
This week's update is crucial for bv 14/Horizon
for me to decied if I shall keep it!
BeoVision Eclipse 55"...BeoLab 18 as FRONT....BeoLab 4000 as REAR....BL19 SUB....BV5 HD....Beoplay V1-40....BC6-26....Beosound 9000....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H8....H6 90´s Rose Gold edt....Form 1....U70...
kuyttendaele
I seriously hope that they iron out the bugs... this seems to be the Vista of B&O...
mr_anders_son
sweden
kuyttendaele:
And from the beginning working multiroomSmile
mr_anders_son
sweden
Someone knows when this week the update comes?
Sandyb
Wednesday or Thursday i think.......pretty sure it was Wednesday on reflection.....
StUrrock
Sandyb:
Ok thanks for letting us know the possible day(s)
Could Struer, then let us know the possible month or maybe even year this long running farce will come to an end.
For many I know this will be their last EVER B&O Tv.
Sandyb
Indeed, though in end, one would hope that the division of labour with LG should make the B&O TV a good prospect again, admittedly without B&O picture processing.....
Simonbeo
Sounds like the Beovision is going out with a bang!
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
Page 22 of 31 (456 items) « First ... < Previous 20 21 22 23 24 Next > ... Last » | RSS
