BV14 | Avant NG | Horizon specs
This post has 16 Replies | 1 Follower
Michael
Sweden
Posts 2,114
Michael Posted: Thu, Sep 22 2016 11:30 AM
I thought a thread about all the new TV´s on Video Engine 3 (Android enabled) should have their own thread.
I read that the new sets will feature a Direct LED-panel instead of the current Edge lit panels (or local dimming on the 75/85" Avants).
As far as I know Direct LED mean that the LEDs are placed on the back of the panel instead of by the sides. However, I am not sure about wether it features a local dimming feature or not. In most cases Direct lit implicate that all the lamps operate at the same zone - in that scenario it would be a global dimming that affects all the LEDs at once instead of individual zones. I am not sure which choice B&O has made.
If they have local dimming and backlit on all the models, that would be a huge improvement. If they just changed edgelit local dimming to backlit global dimming then its a jump backwards in all steps but two - uniformity and maybe also higher brightness possibilities in bright room environments.
The fact that Bang-olufsen.com only specifies local dimming on Beovision 11 and BeoVision Avant 2014 makes me believe that they in fact went with cheaper panels for the BV14/Horizon and possibly also the upcoming Avant NG.
Information from Bang-olufsen.com:
BeoVision 11 - SCREEN TYPE
3D via active shutter glasses, 200/240 Hz LCD panel with edge-type LED backlight and 1.5 D local dimming. Glare polarizer, combined with anti-reflection coating, significantly reduces reflections from incoming light.
BeoVision Avant 2014 SCREEN TYPE
16:9 TFT LCD, glare surface
BACKLIGHT TYPE
55”: Two, edge-type LED 1.5D local backlight dimming
75”: Direct type LED with 2D local backlight dimming
85”: Direct type LED with 2D local backlight dimming
Horizon and BeoVision 14 - SCREEN TYPE (no BACKLIGHT TYPE info available)
16:9 TFT LCD, antiglare surface
Aussie Michael
Melbourne, AU
Posts 3,349
I asked at the dealer and they said the 14 and the Horizon were edge lit.
I thought they said the whole range is edge lit. This means to me that the dimming is separate?
Millemissen
Flensborg, Denmark
Posts 12,356
More information on the new BV's in this training video:
http://www.youtube.com/playlist?list=PLRPmJ785xnMg4QKEL_S-Ia90t8mta8eXs
Michael
Sweden
Posts 2,114
Michael replied on Thu, Sep 22 2016 1:05 PM
Millemissen:
 I've seen that one and it says the same (17:33 minutes in): Direct lit and the beovisions is thicker than before.
Millemissen
Flensborg, Denmark
Posts 12,356
Usually 'direct lit' does not include 'local dimming'.
Much more important than specs to me is, how the tv/tv's perform with the usual mix of sources in the home.
Waiting for more real-life reviews from Beoworlders ;-)
Duels
England
Posts 2,225
Duels replied on Thu, Sep 22 2016 1:48 PM
I may be being dumb here but has a new avant 55 actually been announced and if so how does if differ from the existing one?
Michael
Sweden
Posts 2,114
Michael replied on Thu, Sep 22 2016 1:55 PM
Millemissen:
Exactly what I meant Millemissen :). If so then that sounds like a strange decision to me. And B&O is not writing anything about it themselves so buyers should be aware before they make a trade or buy one - in case picture quality is affected. Specs is important to how a tv performs :).
Michael
Sweden
Posts 2,114
Michael replied on Thu, Sep 22 2016 2:01 PM
Duels:
It has not as far as I know, but it will come
Millemissen
Flensborg, Denmark
Posts 12,356
That is called the BV Avant/NG.
Also described in the video/Youtube link above.
Michael
Sweden
Posts 2,114
Michael replied on Thu, Sep 22 2016 3:41 PM
Millemissen:
That is also what I wrote Millemissen :)
Michael
Sweden
Posts 2,114
Michael replied on Thu, Sep 22 2016 3:49 PM
Aussie Michael:
I'm not so sure they are correctly informed unfortunately.
Aussie Michael
Melbourne, AU
Posts 3,349
Michael:
Ok Smile
Michael
Sweden
Posts 2,114
Michael replied on Sun, Sep 25 2016 10:55 AM
Aussie Michael:
Ok
I find it odd that there is no information about it since it is an important part. Especially worrisome if retailers are misinforming their customers when buying such expensive things.
beotex
Posts 70
beotex replied on Mon, Sep 26 2016 7:55 PM
Any chance we will see the Horizon or BV14 in larger sizes? Or is it only going to be the Avant for greater than 55"?
IA64
Posts 87
IA64 replied on Mon, Sep 26 2016 8:11 PM
Do these TV support  802.11ac  Wifi ?
Millemissen
Flensborg, Denmark
Posts 12,356
beotex:
Can you imagine how big a BV14 in more than 55" would be?
I guess the Horizon will be kept in these sizes to stay a 'lower' prize tv.
Maybe - if it turns out to be very popular - a 55" would be possible.
But - really - noone can answer that question - not even the guys in Struer, I suppose.
Do remember that it won't be long before we will see the first B&O/LG tv's - they will (without doubt) be bigger than 55".
Michael
Sweden
Posts 2,114
Michael replied on Mon, Sep 26 2016 10:08 PM
IA64:
Yes
Page 1 of 1 (17 items) | RSS
