MMC1/4 cartridge volume
Not Answered This post has 0 verified answers | 1 Reply | 1 Follower
Steve
Cape Town
Steve posted on Sat, Apr 30 2016 1:20 PM
Hi everyone
I've got an MMC1 and an MMC4 cartridge - hope someone can help with two questions:
1) the volume of the MMC4 is louder than the MMC1 - is this normal or indicative of a problem with one of the cartridge.
2) the MMC1 sounds crystal clear, however the need guard does not move done far enough to cover/protect the needle. Is this normal or is there an issue? the mmc4 guard on the other hand covers the stylus.
I'm using these cartridges on a Beogram 5005 and a Beogram 6500
Any feedback would be appreciated!
Stephen
pepps
Kent, UK
pepps replied on Tue, Jun 7 2016 11:22 PM
Hi Steve,
I had my mmc4 repaired by Axl - the cover doesn't slide down to cover the stylus either. It isn't an issue. These tips must always be treated very gently anyway.
The decks you're using are different in that the 5005 doesn't have a built in RIAA section but the 6500 does.
If you're playing each deck through different amps you may experience different levels.
Additionally if you're playing the 5005 through the phono socket of a Beomaster with an RIAA stage inside (Beomaster 5000 or 5500 perhaps?) and the 6500 deck via Tape 2 or Aux, you will hear a difference in volume. In this case I would expect the 5005 through a Phono socket to play a little quieter than the 6500 through another input.
I hope another forum member can offer up additional info to help.
Good luck.
Steve:
Hi everyone
Stephen
Page 1 of 1 (2 items) | RSS
