What Are You Working On Now
This post has 1,304 Replies | 20 Followers
Søren Mexico
Mexico City
Posts 6,405
Thank you Menahem, will take your word for it, no experiments, the BM 2400 is PIB to work onSmile
Dillen
Copenhagen / Denmark
Posts 13,058
ONLINE
Dillen replied on Mon, Mar 23 2015 9:34 PM
Menahem Yachad:
25VAC is fine for +/-31VDC - remember that you've got big 5000uF caps, which ups the output voltage.
Menahem, I am not sure, that is what you actually meant to say (it's not quite correct, anyways);
A multimeter will only show an "average" reading of the DC contents of any given measured signal content.
It cannot change its reading fast enough to keep up with the mains frequency (and you wouldn't be
able to read it out fast enough either).
Put a scope to the rectifier voltage instead and you will see, that the voltage does not increase
when the filter caps are connected.
Instead the caps will remove ripple and make the output voltage a more steady DC (filtering out AC)
and it's this more steady DC that results in a higher DC voltage ("average") reading on the multimeter.
First lesson in power supply circuitry. Yes - thumbs up
Søren , check the D50 rectifier. If it's the original part replace it. It was slightly underdimensioned from factory and
this issue was only "rectified" at the very latest production individuals.
Check also the nearby fuse holder on the main board. I've seen cases where the contact pressure had almost
disappeared due to fatigue, causing both intermittent and permanent dropouts.
Menahem Yachad
Jerusalem, Israel
Posts 1,238
"Put a scope to the rectifier voltage instead and you will see, that the voltage does not increase when the filter caps are connected.
and it's this more steady DC that results in a higher DC voltage ("average") reading on the multimeter."
Better said than I did!
tournedos
Finland
Posts 7,356
tournedos replied on Sat, Aug 22 2015 12:12 PM
What do you know, I'm actually working on something. The entertainment system at the sauna cabin (Beomaster 900K type S290, as featured in my long running avatar) needed some maintenance.
The dial lights were out. When both of them are, it is more often than not caused by corrosion in the fuse holder rather than both of the bulbs being burned. There's a dedicated fuse, located apart from the others, that feeds just the dial lights. I have no idea why that particular holder always gets this green corrosion when the rest of the chassis is spickety span.
After a clean, there's light again. Just noticed that a reflector is missing from one end of the dial. I don't have suitable materials or tools to make one over here, so I'll just note it for the future. You can hardly tell it from the outside anyway.
While the cabinet was empty, I gave it a light sanding and applied some wood oil. "Jan 25 1965" stamped in the inside, so this radio is just 50 years old. Now good for another decade, I think Smile
--mika
Rich
Orlando, Florida, USA
Posts 2,598
Rich replied on Sat, Aug 22 2015 9:07 PM
Must be a classic "dissimilar metals" problem.
Søren Mexico
Mexico City
Posts 6,405
Just finished these, new surrounds new caps, new, well she forced me to it, and I need some goodwill for my BL/BM 5000 project
Rich
Posts 2,598
Rich replied on Sun, Aug 23 2015 5:51 PM
And I no longer have the worst frets in the world!
DMacri
United States
Posts 881
DMacri replied on Tue, Aug 25 2015 11:24 AM
Rich:
And I no longer have the worst frets in the world! Blah blah blah, blah blah ba ran
I'd call it a tie. Big Smile
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
elephant
AU
Posts 8,219
elephant replied on Tue, Aug 25 2015 12:18 PM
DMacri:
I'd call it a tie. Dom
BeoVision Avant, BeoSystem 5000 (BM 5000, BG 5005, BC 5000, CD50), BeoSound 4000, BeoLab 2500, BeoVox S-45, BeoVox S-45.2, RL-140, CX-50, C-75, CX-100, 3 MCL82 link rooms, A8 earphones, 4001 relay, H3, and ambio
Let's hope my wife doesn't try make it a trifecta Sad
BeoNut since '75
Orava
Finland
Posts 991
Orava replied on Tue, Aug 25 2015 1:52 PM
Søren Mexico:
Speachless...
Menahem Yachad
Jerusalem, Israel
Posts 1,238
How did you manage to bribe for a South African hunting license for those zebras?
Søren Mexico
Mexico City
Posts 6,405
Menahem Yachad:
No need Menahem, this is from a Mexican zebra, they change (shred) their skin every year
Menahem Yachad
Jerusalem, Israel
Posts 1,238
Soren, you made me laugh!!!
Evan
USA
Posts 3,616
Evan replied on Wed, Sep 30 2015 6:47 PM
Currently sorting out a system for a friend of mine. I'm pairing up my BeoVox 2600 along with the BeoMaster 1000.
It turns out that my problematic 2600 has a misaligned woofer. Before I start selecting a pair of replacement woofers, I was wondering if any of you have an original problem-free SEAS woofer I could buy?
Here is the woofer:
Beo4 'til I die!
Rich
Posts 2,598
Rich replied on Wed, Sep 30 2015 7:01 PM
Can't you just take it apart and rebuild it?  I know that's easier said than done, but in the long run, isn't that the best approach?
Evan
USA
Posts 3,616
Evan replied on Wed, Sep 30 2015 7:19 PM
Rich:
I guess I don't really feel like building woofers right now. But I suppose I could look a little more closely when I get home. After all, the woofer is misaligned and its not going back into the cabinet as is...
My options are:
  1. buy an orphaned/surplus original SEAS driver
  2. buy a pair of new woofers off the shelf woofers
  3. rebuild original woofers
I think the last thing I want to do is rebuild a woofer - another can of worms I'm not interested in opening at the moment Stick out tongue
Beo4 'til I die!
sonavor
Texas, United States
Posts 3,704
sonavor replied on Wed, Sep 30 2015 7:39 PM
Hi Evan,
Back in 2010 I had a twelve inch Yamaha woofer out of an NS-690 that had a misaligned magnet. I sent it to The Speaker Shop for repair and they did a good job (it's still working fine). At that time The Speaker Shop was located in North Lima, Ohio but they have since moved to Savannah, Georgia. You might contact them and get an estimate for a repair. It may be less expensive than buying a replacement.
John
Dillen
Posts 13,058
ONLINE
Dillen replied on Wed, Sep 30 2015 7:44 PM
Evan,
I have an original. - But it's in Denmark.
Rich
Posts 2,598
Rich replied on Wed, Sep 30 2015 8:04 PM
I don't have any projects going right now .........
Evan
USA
Posts 3,616
Evan replied on Sat, Oct 10 2015 8:58 PM
Greetings from my second bedroom stereo laboratory -
2600 Update - I decided to just buy the woofer Martin had on hand.
Now my battle continues with the BM1000... All capacitors (except for the axials and those ridiculous dual capacitors at the left corner, out of frame) have been swapped. Now I have gone to power up the unit for a functionality check and the two red resistors in the right channel section have started smoking! Then I swapped the trimmer (crudely) and the resistors still get mighty toasty, even with the trimmer cranked to the max.
I'll add that the DC offset reading is a staggering 14.8vdc for the right channel and 13.4vdc for the left.
Thoughts? Confused
Beo4 'til I die!
Evan
USA
Posts 3,616
Evan replied on Sat, Oct 10 2015 9:09 PM
sonavor:
Hi Evan,
John
Thanks for the info, John! Too bad they moved so far away from me! I'm sure the distance wouldn't matter any way.
For this particular project I am going to skip rebuilding the driver. However, I should still get the quote, I am curious now..
Beo4 'til I die!
Menahem Yachad
Jerusalem, Israel
Posts 1,238
Evan
Most of those old fat carbon resistors are so far out-of-spec, it's not even funny anymore.
While I'm not going to speak specifically for the BM1000 - I've never worked on one, I can tell you that I regularly swap out at least 50% of those resistors on other B&O machines of a similar age.
That's probably your problem right there.
Replace them with Vishay PR03 for the big ones, and PR02 for the smaller ones (ex-Philips BC Components).
Also check the bias current resistors - replace with Vishay MRA-05 (previously known as Mills)
Menahem
Dillen
Posts 13,058
ONLINE
Dillen replied on Sun, Oct 11 2015 7:21 PM
Evan,
The new trimmer seems to be a 5K component, which makes me assume that this is a type 2316 or 2317.
If you measure the DC offsets before the output series capacitors (the large ones you call doubles - but they
are in fact just separates), the offset is about right.
The amps supply is 30V and it's not a dual supply so 50% of the supplied voltage on the center rail (midpoint) is correct.
If you measure AFTER the series capacitors - they are both bad.
Smoking emitter resistors points to a too high current flow through the output stage transistors.
This could be a problem with the idle current circuit or the output stage itself.
In your case, where the DC offset is not too far off, I doubt it's an output stage fault - but I cannot
rule it out completely, so check both.
Check the NTC too. I've seen one or two go open circuit.
Note that the voltages stated in the schematics are negative to ground.
That was common at the time, maybe a left-over from valves.
Evan
USA
Posts 3,616
Evan replied on Sun, Oct 11 2015 8:25 PM
Dillen:
Evan,
If you measure the DC offsets before the output series capacitors (the large ones you call doubles - but they are in fact just separates), the offset is about right. The amps supply is 30V and it's not a dual supply so 50% of the supplied voltage on the center rail (midpoint) is correct. If you measure AFTER the series capacitors - they are both bad. Smoking emitter resistors points to a too high current flow through the output stage transistors. This could be a problem with the idle current circuit or the output stage itself. In your case, where the DC offset is not too far off, I doubt it's an output stage fault - but I cannot rule it out completely, so check both. Check the NTC too. I've seen one or two go open circuit. Note that the voltages stated in the schematics are negative to ground. That was common at the time, maybe a left-over from valves. Martin
You are correct - type 2316, also correct regarding the 5k trimmer.
This morning I just turned it on and gave it another chance to behave.
The bias current is set to 18mv, and it seemed to be fine, resistors cool to the touch. I hauled it upstairs and it plays music.
How on earth do I replace those big DC caps with regular ones? I bought two Nichicons to replace them but put off that task after realizing they are dual capacitors (at least, that's correct term I think..).
Beo4 'til I die!
Evan
USA
Posts 3,616
Evan replied on Sun, Oct 11 2015 8:29 PM
Menahem Yachad:
Evan
Menahem
Thanks Menahem! If I put together another parts order, I'll include the resistors.
However I'm not sure if I will get to it, at least not yet. I am just trying to help a friend of mine get a classy vintage stereo to provide tunes while he figures out what he wants in a stereo for the long term.
Beo4 'til I die!
Dillen
Posts 13,058
ONLINE
Dillen replied on Sun, Oct 11 2015 8:31 PM
Well, I shalln't say, that they haven't been replaced by dual capsat some point  - they are not in your photo -  but the original caps
are separate (= conventional) caps, just with three pins, where the third pin is for mechanical support only.
You can replace with modern caps and leave the third (unconnected) solder pad empty, just remember to get the polarity right.
Søren Mexico
Mexico City
Posts 6,405
I made my BM 1000 type 2317 some time ago, here
Evan
USA
Posts 3,616
Evan replied on Thu, Oct 22 2015 4:02 PM
Dillen:
This was the best news I've gotten in a long time! Yes - thumbs up
I replaced them last night along with a few remaining items. The biggest change was the new woofer, I also re-cabled and re-terminated the speakers. I plugged it in around midnight last night and listened for about an hour, but had to keep it at a reasonable volume. To say the very least, the system sounds incredible. I can't wait to go listen a little louder during lunch Big Smile
Beo4 'til I die!
Guy
Buckinghamshire
Posts 2,513
Guy replied on Wed, Oct 28 2015 10:09 AM
I've just put this two-way BC2300 back together after an overhaul.  I bought it on eBay.de with 'faulty doors'.  It was shipped in the original packaging and I reckon it must have been dropped from a great height (by dhl) at some stage!  With the cold weather and age of the plastics the damage inside was quite bad, so I spent several days 'aralditing' the chassis back together.  Then replaced the door belt, re-seated the door wire and put it back together - everything works well!  It was also a good excuse to get my BL4000s out of their box and test.
Orava
Finland
Posts 991
Orava replied on Fri, Nov 27 2015 1:04 PM
testing...
chartz
Burgundy, France
Posts 4,126
chartz replied on Fri, Nov 27 2015 2:53 PM
Mmm. Beocord 5000. 'Got two of those, both working!
Jacques
Orava
Finland
Posts 991
Orava replied on Sat, Nov 28 2015 9:57 AM
three here, looks like led mods do not work on control swithc section...
chartz
Burgundy, France
Posts 4,126
chartz replied on Sat, Nov 28 2015 8:01 PM
I haven't tried LEDs at all. I sort of dislike them on these oldies. You know, I have 50 year-old hifi devices that still have their original bulbs... Careful transport is everything here.
I'm sure Rudy (Beolover) can advise.
Jacques
Orava
Finland
Posts 991
Orava replied on Sun, Nov 29 2015 12:14 PM
Main problem is that solenoid for recording does not have strength to operate slides on the circuitboard.
Menahem Yachad
Jerusalem, Israel
Posts 1,238
The solenoid has the strength.
Unless there's a short in the coil winding, there should be no change in its performance.
Perhaps the plunger is sticking inside the tunnel, or the capacitor which provides the oomph is dead.
Orava
Finland
Posts 991
Orava replied on Sun, Nov 29 2015 5:46 PM
ORL3? Slideswitch was sticky, but now it doesn't stay on...
Orava
Finland
Posts 991
Orava replied on Tue, Dec 1 2015 9:39 AM
Um, should read manual..
Anyway, what is THE right method to assemble top flap spring?
chartz
Burgundy, France
Posts 4,126
chartz replied on Tue, Dec 1 2015 6:55 PM
Why did you disassemble it in the first place? I didn't, so I can't help.
Jacques
Orava
Finland
Posts 991
Orava replied on Wed, Dec 2 2015 7:08 AM
Did not realize it is so dificult. It is on the place but was not easy, so thats why I ask.
lausvi
Helsinki - Finland
Posts 688
lausvi replied on Sun, Jan 17 2016 2:28 PM
I *finally* got around trying to fix my Beomaster 7000's tuner and my Beolink 7000.
The BM's tuner went silent already over a year ago when I was trying some re-capping to improve the tuners workings. I finally found a dodgy soldering joint which brought it back to life. I enjoy listening to radio while working on something else, and it's nice to have it back. Eventhough I must say that it's almost continuous flipping thrue channels to avoid ads and bad (modern) music!
Today I had a look on my Beolink; it had it's batteries gone flat over a period of non-use (mostly the time while the BM7000 was not in use due to the tuner fault) and it wouldn't keep charge anymore. Also while in charger the two-way IR didn't work anymore. I had repaired it once before (replaced two electrolytic caps around the IR parts) but I had not replace the two small SMD caps under the shield (as I couldn't then figure out how to get the shield off - also I had never worked on SMD parts at the time and didn't want to risk damading the board). It had worked fine for a while but clearly it was now time to get all those caps replaced. Sorry for not having pictures, but I have now assembled the BL and it's working again. I replaced the Ni-Cd batteries too and I am now giving it a first-time charge.
I hope to have gained some more years of life for the BL7000, it's surely a device I wouldn't like to open again and I just dread the thought of doing any more disassembly of it!
I am glad to have my 7000-system working again and I must say I love it Yes - thumbs up
Page 29 of 33 (1305 items) « First ... < Previous 27 28 29 30 31 Next > ... Last » | RSS
