Beogram 2000 is dead
Not Answered This post has 0 verified answers | 22 Replies | 1 Follower
riis
Denmark
riis posted on Tue, Feb 16 2016 10:14 AM
I have got a faulty BG 2000 from a friend. Nothing happens when I plug it in, just a slight hum from the cabinet. I've opened it for inspection but I can't see what' s wrong.
The BG 2000 is very different from BG 4002/4004 which I have some experience with.
Should it go to the recycling centre?
/riis
the_o_master
Of course it should not go to the recycling center. This kind of question is not allowed here on Beoworld Big Smile
There are few very skilled guys here who can help you with BG2000. But first: which version of BG2000 do you own?
This:
Or this:
Particular the old one, type 5240, is a rare version (with its black alu-strip on the dust cover) and one of the better sounding B&O turntables. It belongs actually to the same series as BG1200/1202/1203/3000 which are all very desired and collectable.
Regards / Theomaster
Vintage Bang & Olufsen
riis
Denmark
riis replied on Tue, Feb 16 2016 12:39 PM
It's type 5244.
/riis
Orava
Finland
Orava replied on Wed, Feb 17 2016 7:12 AM
If it has not belt, it could be in playing position, and humming is from motor.
Without belt it cant return to rest position.
riis
Denmark
riis replied on Wed, Feb 17 2016 6:40 PM
Orava:
I have put the Beogram together again. The belt is on and now there is no humming. Unfortunately it is stil completely dead. I think i'll start with the LIFT button to see if there is any connection.
How can I test if the motor is working?
/riis
Orava
Finland
Orava replied on Wed, Feb 17 2016 7:41 PM
Does it look anything like this inside?
http://forum.beoworld.org/forums/p/18378/160188.aspx#160188
riis
Denmark
riis replied on Wed, Feb 17 2016 7:59 PM
Orava:
I think so. I'll open it again tomorrow and have a look.
/riis
riis
Denmark
riis replied on Wed, Feb 17 2016 8:07 PM
Are the 1203 and the 2000 similar apart from the lids?
/riis
riis
Denmark
riis:
Orava:
/riis
It looks exactly the same inside. It's very clean and there are no broken parts, so I can't see why it shouldn't work, but it doesn't........
It's very dry, can't see any oil or grease at all. Is it supposed to be like that?
riis
Denmark
and another one
riis
Denmark
and the last one
Orava
Finland
Orava replied on Thu, Feb 18 2016 9:53 AM
It is like my 1203 then. It is supposet to work when you pushed lift, thin rod is twisting white lever "offplace" and allowing microswithc in white box acting.and center cog turning. It is stupid simple really :) Moteor should start as soon as microswithc acts.
riis
Denmark
Orava:
The BG 2000 is now running. To be honest I don't know how except from some TLC. Thanks Orava for explaining how the deck works, very different from the BG 4002/4004 I have brought back to life.
There is a little noise from the deck when running. Should I oil and lubricate? If yes, where?
The lid is off. Does anyone know how to put it back?
/riis
Søren Mexico
Mexico City
The speed change mechanism tends to freeze up because of old grease inside all the movable parts, also the motor may make a little noise if not taken apart and cleaned, lubricated and adjusted, also check Oravas thread with the felt pad in the speed mechanism, just oiling wont help, the only way is to disassemble and clean it.
Orava
Finland
Orava replied on Thu, Feb 18 2016 6:35 PM
If it looks like this
http://forum.beoworld.org/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.00.27.20/bg2k.k.jpg
yuo have to do some craftwork
It should have overhang(?) tab(?) sliding between top plate and wood
Page 1 of 2 (23 items) 1 2 Next > | RSS
