How to identify Beocom 6000 MK1 and MK2 charging stations (table or wall)?
Not Answered This post has 0 verified answers | 9 Replies | 1 Follower
TWG
TWG posted on Sun, Feb 7 2016 12:41 PM
how can I identify if the charger of a Beocom 6000 is for the MK1 or MK2 version?
I want to buy a table charger with the following data:
TD 318932
Item no: 1062929
Serial no.: 1983....
Is this MK1 or MK2? Is there a list to identify those things?
Guy
Buckinghamshire
Guy replied on Sun, Feb 7 2016 12:52 PM
I have one with exactly the same numbers and use it with a Mk1 BC6000.  It has an EU 2-pin plug.
And I have another downstairs with the number 1040929 which is also for Mk1, but has a UK plug.
TWG
TWG replied on Mon, Feb 8 2016 8:04 AM
Thank you for your help!
Is there a list or s.th. where we can check globally if it's MK1 or MK2?
9 LEE
Eastbourne, UK
It's pretty straightforward to identify a Mk1 and a Mk2 BeoCom 6000 Charger.  It's all on the contact points!
On the Mk1, the contact points are perfectly round - like so....
9 LEE
Eastbourne, UK
On the Mk2, however, the charging points are larger - more or a round ended rectangle, like so....
9 LEE
Eastbourne, UK
9 LEE replied on Mon, Feb 8 2016 9:10 AM
The phones match the charging pins - so the charger contacts on a Mk2 handset are the same size as the charging recesses on a Mk2 handset (being larger).  This is the sole reason you cannot sit a Mk2 handset on a Mk1 charger... the larger contacts on the Mk2 handset are simply too big for the small, round charging recesses on the Mk1 charger.
Conversely though, you CAN charge a Mk1 handset on a Mk2 base as the small, round contacts fit easily into the larger 'round ended rectangle' recesses on the Mk2 base.
Make sense?!  LOL
Lee
Guy
Buckinghamshire
Guy replied on Mon, Feb 8 2016 9:40 AM
I am sure that's useful Lee, but did you delete my other post with the link to beophile?  I thought that was useful also!
TWG
TWG replied on Mon, Feb 8 2016 9:42 AM
Thank you Guy and Lee for clearing it up. The photos are helpful.
9 LEE
Eastbourne, UK
9 LEE replied on Mon, Feb 8 2016 10:38 AM
Guy:
I did indeed Guy!  I also sent you a message!!
Please feel free to repost the link, but I felt that the images gave the conclusive reply.
Lee
Guy
Buckinghamshire
Guy replied on Mon, Feb 8 2016 11:05 AM
Thanks for clarifying - no message received though!
EDIT: Message now received - thanks Lee, all understood!
Page 1 of 1 (10 items) | RSS
